Redmi Note 8
GoodBetterBest
I gotten my Ocean Blue Note 8 Pro 64GB from this seller. Upgraded to 11.0.6 and NFC working fine but had some issue with my network (stuck on H+ and not 4G) the past few days, factory reset my phone, redid GPay, tried it to pay at McDonalds and it works.
What method you use to back up / restore ? Can restore directly without having to put back all the icons to the home screens and app drawer ?
carboy00
Backup Home Screen and apps to Mi Cloud. Then can restore from there after you reset the phone. I didn't use any restore, I just install and reinsert apps to home screen manually.
Posted from PCWX using POCOPHONE F1 Rosso Red
carboy00
Submit bug report first since there's significant number of users facing same issue. Global Android 10 update has yet to be pushed out but it should be soon (CN, EU and RU versions all already got it), maybe the upcoming update will fix the issue.
Pocoyoz
Some apps can autostart even when autostart are disabled.
Some apps can run in background even when close in background are selected. :(
Sent from Amazon using GAGT
cleavage
Does note 8 pro only comes with 2 pin plug even for global/local version? How about note 8 pro. Does it come with 3 pin plug?
GoodBetterBest
Mine comes with 2 pin. I don't know about others.
Come to think of it, I could have msg the Global Store and ask if they can send 3 pin. May be they do and would have sent to me.
FYI. There is a on/off Lazada Flash Sale for Motorola black colour 3 pin 18W QC3 charger for $4.90/-. If you need 3 pin, can look out for it.
Zinc-Oxide
Sold my note 8 pro for $270, got a very good condition second hand Samsung note 9 instead for $420. Maybe is just me but I prefer amoled screen and one UI. I feel that MIUI still not very stable as one UI.
Plastick
Anyone facing wifi being 'disconnected' out of sudden and the connected wifi network status written as "DISABLED". have tried connecting to mobile hotspot on the same instance but no issue. the temporary fix is restarting hp.
redmi note 8.
GoodBetterBest
GoodBetterBest
Yup it is a little troublesome. The Android 10 update is coming (beta Stable testing now), hope it doesn't break NFC again.
Posted from PCWX using Redmi Note 8 Pro Ocean Blue
I think it's during the installation, something gone wrong.
Problem with Xiaomi is that they don't reply to bug report and just leave you hanging there. They should have system checkpoint like in Windows. I can just roll back the update easily.
1.koln
redmi note 8.
I got same issue occasionally
Also have to restart phone to fix
KingOfSbw
I jus bought a redmi note 8 pro 6+128gb at S$308 so call locate set with mi sg 1 yr warranty
Worth it ma?
This will be my spare phone
Sent from Samsung SM-G985F using GAGT
