Redmi Note 8
pLueAr
after the update, i cannot find the split screen function. anyone facing the same problem?
aearthr
Hi, how long it take for your delivery? I ordered redmi note 8 pro on shopee xiaomiofficialstore.sg on 9 Apr. Till now the last update i have is parcel in transit from China to Sg on 11 Apr. I messaged them on shopee, and the auto reply is due to easter holiday in HK, instead of 5-15 days, it will be delayed for 2-3 days. This is so long. Wanted to replace my mum's old phone during this covid period.
stylechap
You can't expect airfreight to be working at normal schedule at this time right :)
matthiasgoh
Same problem. I ordered on 7/4, shipped on 11/4.
Till date still stated parcel in transit from China to SG.
Pocoyoz
The provided case become study after some time :(
Sent from Amazon using GAGT
Squaredot
Hi, how long it take for your delivery? I ordered redmi note 8 pro on shopee xiaomiofficialstore.sg on 9 Apr. Till now the last update i have is parcel in transit from China to Sg on 11 Apr. I messaged them on shopee, and the auto reply is due to easter holiday in HK, instead of 5-15 days..
I also ordered on 9 April, parcel in transit on 17 April. Real tortoise.
i1magic
Any of you here using Redmi Note 8 Pro with Starhub?
Whenever I receive a voicecall, the 4G will be disabled and my data doesn't work liao. Any of you experienced the same thing?
Anybody here using Redmi Note 8 Pro with M1? My contract is expiring with Starhub, will switched to M1.
eip1234
Did you enable VoLTE? I presume RN8Pro supports that ...
HUGO15481
Does this consider as export set? Will it come with 3 pin plug and 1 year warranty ftom Xiaomi Singapore?
Can share the shopee link?
i1magic
I guess so. There are settings which I enabled VoLTE, like this :
But after I have done this, I do a voice call and then run YouTube, no data.
Anybody on Starhub has this problem?
cscs3
Because you are not on VoLTE. We you do voice call, it is actually on 3G.
bloodyshot
Anyone having the same issue as me? Really need some help here.
When i plug out the USB cable from the charger after charging for 1 hour, the tip of the USB cable is burning hot!! I cant even hold it for my than 1second, i could only like tap it rapidly as though its like touching a hot kettle.
I understand that the quick charge 3.0 feature charges my phone at about 2.82Amp which generates more heat. But the heat is too hot, and when i smell the charger's USB port it has like a small burning smell.
Does your charger goes that hot too?
