Redmi Note 8
Steyr69
The price of Note8 Pro shoots up to 369 now...wtf
Sent from Xiaomi MI A1 using GAGT
eting72
just got mine yesterday at 279 and voucher can be used. think they'll adjust price now and then
Sent from OnePlus HD1900 using GAGT
ZhuTou!
What's the lowest price it went to? Before 369, I saw it was 279.
369 is the standard price without any promo for 6/128
U go lazada also can see 369
Only shopee can see 299 for now
Flash deal will see 279
Lowest is 239 i think, during xiaomi anniversary
i1magic
Anyone having the same issue as me? Really need some help here.
When i plug out the USB cable from the charger after charging for 1 hour, the tip of the USB cable is burning hot!! I cant even hold it for my than 1second, i could only like tap it rapidly as though its like touching a hot kettle.
I understand that the quick charge 3.0 feature charges my phone at about 2.82Amp which generates more heat. But the heat is too hot, and when i smell the charger's USB port it has like a small burning smell.
Does your charger goes that hot too?
Try another cable on the charger. Then try the hot cable on another charger.
Report back your findings.
i1magic
Under the SIM option, go into the SIM1 or 2 depending on which sim slot you used. There is a VOLET option.
Do take note your phone model is needed to supported by the telco before you can use VOLTE.
How do we know whether which phone model are supported by our telco?
Anybody here on Redmi Note 8 Pro and with Starhub can try :
Do a normal voice call, then see whether can you watch video on YouTube.
I would like to find out this.
Anyway, I will be porting over to M1 next week liao.
i1magic
Did it help by rebooting your phone?
If still the same, chances are, the Starhub coverage at your location is not strong enough. Try other locations farther away when possible and see how it goes ...
Rebooted liao, tested and still the same.
Now ** period, no chance to try other location yet.
i1magic
If you have m1 post paid sim try the volte and wifi call options and see if it’s activate. If yes Meaning your phone is fine it’s likely you do not have that service activated or not strong enough signal (must be in 4G / LTE) , call StarHub to check if they activated for you, esp if your SIM card is very old
So it could be SIM card issue also?
I will be porting to M1 next week liao.
