Redmi Note 9
teoph04
After changing to the original clear case, no problem alr... Thanks
Posted from PCWX using Redmi Note 9 Pro
ronnie
Most probably is due to the poor design of your 3rd party casing. The earphone is located on the top edge & comes with a proximity sensor, just compare it with the original casing.
btw for those of u guys whom bought tp glass (both black border / clear types), does it come with cam cutout hole or was it covered?
My tempered glass screen protector is one whole piece. Anyway, the SP is slightly narrower in width than the actual display area. However the length is more than adequate to cover.
Broadwalk
Do you attempt to cover the SP on top more than the bottom of your phone? :o The width is somewhat truncated if manage on both sides. :o
gz0707
happened twice today liao
i was on wifi still connected
but unable to browse internet or use any app which requires data
this happened when i left the phone alone for a period of time and then picked it up again
to get data working again, i had to disconnect wifi and connect again
yup, that's the same issue - must disconnect from 5G wi-fi to get all data apps to run ... kinda weird ....
teoph04
How's your battery consumption and drain?
:o
Yesterday morning 8am, standing at 94%, then browsing FB, IG, HWZ, clash royale, all casually. Then at night about 11pm, battery at 45%.
Till this morning then charge at around 11am at 29%.
zzzzzzz
anyone using temper glass?
does it stick well against the edges?
realised the phone came pre-applied with plastic protector
duno if i should tear it off immediately and put glass protector
zzstormriderzz
I have got my 9 pro phone just today. Looks super huge, maybe bulky to me. Also why the charging plug is 2-pin (round) type? How about u guys? Did they send me the wrong plug or what
zzzzzzz
yes the charger is 2 pin
on the other hand i found it too small as i am used to mi max sized phones
Broadwalk
I think better change to temper glass. :o The thin film is really normal layer of film. :o
Mine from Nillkin smaller than actual screen by 1~3%. :o
hkchew03
So that means I need to get a new 3-pin charge. Or live with the 2 pin charger. Haiz
Why you sound like 3-pin is a big deal?:s22:
Chargers are usually just plugged and stay there forever, if you need to move it around, better to get extra charger.
zzzzzzz
https://c.mi.com/thread-3093883-1-0.html
Highlights
FIX : Wi-Fi connection was interrupted in some cases
System
Updated Android Security Patch to May 2020. Increased system security.
based on what the XDA people posted, apparently miui v11.0.8.0 has been released to fix issues with wifi
but my set is still not showing any updates available
the link i posted above is for 9s, anyone got info for 9 pro?
Backlash
IMHO, Tempered Glass there are only 2 options. Smaller size fully clear tempered glass to prevent white edges or almost full size with black edge printing to conceal the white edges however with part of the screen truncated.
Unless you want to go for soft film type that wrap around the edges, those are the only options u have. And the soft film type is going to be tough to applied. Been there, done that.
For cases, my experience with cheap or even expensive cases can be a hit or miss. 50/50 chances of a good fit or lousy fit.
Even the stock clear case provided has issues such as the bumper area for the camera.
