Samsung Galaxy note 2 tips & tricks plus issues.
bojangle
guys,
when viewing a photo or webpage, when u turn the phone slightly, it rotates to portrait/landscape. Is there a way to stop it from rotate like a shortcut key instead of going to settings? like ipad hv a button on the side to lock rotation.
albertchng
guys,
Pull down the Notification page and disable the Screen Rotation. How difficult is that?
yuyulili
Hi guys, is there a way to reject a incoming call without having to swipe to cancel? Like pressing the on button twice?
Reason: sometime in meeting, phone keeps ringing, press once on button can silent the call but no way to cancel call without having to swipe the phone.
albertchng
Set ringer to off or vibrate when in meeting, if call comes in just swipe to cancel the call, what is so difficult?
carey
Go to settings
You can use the power button to reject calls...hahah
Or use motion control - flip the phone over to silent the call :s13:
ikebukuro
hi all my note 2 the recent apps menu suddenly doesnt appear..my home button is working perfectly fine...have to restart phone to make the recent apps menu appear again. this has happened several times..any pros can help? thanks
icyboiboi
anyone encounter after the latest firmware update, signal always change to G instead of 3G oR H+
please help
local singtel set with starhub sim.
before update is all fine.
OldTech
how to install apps in SD card instead of in local memory? I don't want to root also. Is it possible?
jarylw
Have been trying to find but no joy. Settings then ? Tks in advance
Dialer - Menu button - call settings - call answering/ending
*to access dialer press the green phone icon in your default home screen. Dialer is the screen with your dialing numbers
monkey18
i accidently disable my playstore and now can loctae the icon.... how to retrieve back ?
yuyulili
Found it but it doesn't cancel a call by pressing the power button. Weird..
Refugees
Yes.....try this link outside of whatsapp or go sms and see if you can see the 2 emojis at the end. If cannot see then most probably is either you're using a custom font that doesn't support emoji, or Samsung fool around with the default jellybean fonts. I'm not using Note 2, but iirc JB supports emoji.....
unable to see the emojis as well..
captylor
Isn't it the second option "The power key ends calls"?
And as a common courtesy, you should always try to put your phone into silent mode before a meeting.
tohchr
Put it in block mode better..
