Samsung galaxy note jelly bean
Modd-36
My battery lasted 11 hours yesterday using lots of whatsapp, music, surfing the net, checking mails and watching youtube videos (those 10 minutes and lesser).
Will monitor again
lawlaw77
Anyone know how to mount back sd card? I accidently dismount it. I have try take out the sd card and put back, but it still prompt me safe to take out.Anyone can help me?
djzilch
hey guys im getting this weird message when tried to update using kies to stock jb
Failed to convert to upgrade mode. Please try later.
any idea how to fix? i tried with both my imac and my macbook pro and got the same results every time
bobaccord
another area of settings. what keyboard u using? If it's Samsung keyboard.
Go Settings>Language and input>Samsung keyboard> key-tap vibration
uncheck it
Thanks :), I manage to unclick the vibration but I retain the sound.. quite cool (I know, drain battery!)
Rgds
Bob
bobaccord
Factory Reset after JB upgrade
Hi
I did a factory reset after upgrading to JB. It's much better now. Smoother n hardly any unwanted lag :)
Put on Power Savings mode most of the time, and the battery is ok.
Just wondering, I have been using my NOTE for > 1 year, perhaps go and buy an original SAMSUNG battery & enjoy it for another year.
I luv my NOTE now, with the JB....
Rgds
Bob
gws898
Does it make a difference between factory reset and without factory reset?
The battery performance will be better after factory reset?
When I turn on wifi it's 90%, after only update a few apps around 10 mins it drops to 81%. Although I didn't do factory reset after update and power saving is on.
Henabi
the power saving feature is useless de. without the power saving feature. power last longer
Modd-36
Yup. Kinda agree with this one. Power saving is more like power sucker.
Just disable locations, syncing and whatever all those can already.
Henabi
battery drain update:
left home for.work at 8am.
batt at 95%
WHATSAPP+LINE+WECHAT+INTERNET SURFING+Music player.
right now batt at 90%. 8:23am
later reach office gonna check how fast note will recharge via PC usb
Jurong640
the power saving agreed. Like no use. Battery still drain. I just un-installed 2X Battery which off data when screen is off to "save power".
However with the app installed or not installed, still the same
pcie2005
i flashed the Netherlands one some time ago. Can I flash back to Singapore's? Shld I use the Singtel one or Starhub? I am on M1 and I don't see the M1 version...
slowpokie
uncheck it
thx got it already ! am still wondering any app or software can type chinese easily without going to setting to change to google pinyin,
my note 10.1 does it easily with a earth sign beside like IOS made it so much easy when i wanna type stuff in chinese for movie app
Jurong640
im using the Samsung keyboard. Other than english in it, it have chinese too. Just swipe the spacebar it becomes chinese. Add chinese language at the same place at keyboard settings.
