Samsung Note II LTE problem and issue
Ralptc
Does anyone encounter "Your device has been modified. No software updates are available" after updating via OTA? Current firmware in my Note 2 LTE is JR003C.N7105XXALJ3.
"Your device does not support software upgrading via kies"
Any ideas??? Thanks!
I got this error also, just install and run trangleaway, got to wait for awhile (have no idea wait how long but next day i tried ota, i don't have the error already). :):)
dexterchua88
I just did a restart and it's gone. Maybe that's the solution. :s13:
Daidee89
Was told my SGS3 on ICS so cannot move apps to SD card... SGN2 on JB... can move the apps from phone to SD card? asking as considering changing to SGN2...
Can anyone confirmed this? Note II can move apps to SD card meh? without root. If yes, pls guide me! Thanks.
Big bear
hi all need some help regarding the s-pen,when i gt my n2, whenever i pluck out my s-pen a s-note window will pop out,nw dunno wat i do, whenever i pluck out my s-pen e s-note window wont come on liao.
any1 know hw to set back again?
Thx
NgiaoCi
anyone had prob connecting it to Kies via USB? I keep getting stuck at the 6GB internal mem. I want to transfer my contacts over from my existing S ..
Moving ur contacts from the existing S into ur google account is much simpler. Then just syn contacts on ur N2 with e same google account and u r done.
justln
Thx
Settings > S Pen > Open Popup Note.
Daidee89
I need help. I have received 2 weird notification today appeared at the notification bar. It says something abt pretty girls. Virus? -. -
tohchr
Lol.. u downloaded porn!! What is your latest installed application?
davi502
Look up and download air push detector app from Google play.
Daidee89
I will try that. Anyway i have another problem i just realised the google. Map is very very inaccurate with 4g. But when using wifi it is? Sigh. Why so many problems de?
davi502
What do you mean inaccurate? It shouldn't make any difference whether it's on mobile data or wifi
Daidee89
When im on wifi. It shows exactly i am the block im staying. But when using 4g it shows like 100-200metre away. -. - i tot it will be same as well but its not.
Jhyun
Did you turn on GPS when using 4G for Maps?
Daidee89
Can someone help me? Its soo weird! The map is only accurate when i on my wifi even though i nvr connect it to any wifi. Anyone? Pls
satch
On data network it depends on where ur nearest base station is...so I heard.
Daidee89
But i on wifi without connecting to any and it straight jump to accurate? Even though im on 4g. As long as only i 'on' my wifi den it will be accurate. Am i the only one having this issue?
satch
http://support.google.com/maps/bin/answer.py?hl=en&answer=1725632
fluffyfiona
Hey check with you guys, is there something wrong with my Note 2 as when I hover my Spen over the bottom right corner, the air view cursor flickers abit and sometimes cannot detect it?
