Seems like total of 11 selections today over AMK and Bedok.
still no clementi
still no clementi
Dont think clementi will be so early. Probably end august?
If you applied using MCPS scheme but your balloted number exceeded the available units, means you were unsuccessful in that initial 30% allocation for MCPS scheme, and you subsequently got your number with just 1st timers status alone. Cause if you were successfully allocated that initial 30% under that scheme means your number would be guaranteed to be within that number of available units.
date released. 21 Aug
Nice. Even earlier than mine. Mine only 26th august. Probably cos your queue no is very small
What your Q no.? Mine is 45 4M yet to receive selection date yet. Dunno still got chance or not.![]()
My queue number has exceeded the available units by almost 3x, just receive the appt letter and it indicated that my parents need to be present due to MCPS briefing... i'm puzzled...
u applied for 4rm bukit merah also? if so, check your email, or login to HDB to check...
That is interesting. How’d that happen. Cause missing that initial 30% allocation, means you’re just into the first timer left over pot. No clue anymore. Hahahahaha.
Imo, i believe once u opted to use the scheme, be it, it gives you a good number or a normal number, u have to stick to it as you were given the extra chances.
So this was the article clarification from HDB due to a couple's situation back in 2015.
Straits Times Article
So based on this and how the balloting works for SBF (Post #201 of this thread). Through the article, the couple was also led to believe with their appointment that they are under the MCPS scheme. However, when asking the officer during the appointment if they do without the scheme, can they retain their number. In their case, they did, cause it happen to fall into the 3rd scenario that HDB said might happen, which is very rare.
My interpretation of that 3rd scenario is couple applied using MCPS. Failed that initial 30% pot. Got thrown into the next 1st Timer with no Schemes pot and managed to get picked there for the initial numbers for available houses. So appointment was still informed as with MCPS scheme even though technically was only under 1st Timer with no Schemes. So when down to remove the scheme, recalculated and realised no change in queue number cause, well, they were never picked in that initial 30% pot anyway.
So this led me to believe that all application under MCPS scheme regardless of success, will be said to have used the scheme to attain the queue number. Which I guess would make general public feel more inclined to use such scheme, which for the government side of things, is what they want as well. Kids near parents to take care of them when older. So that's 2 birds with 1 stone right there.
