SCB SingPost/Spree Card
saffronsatire
those still holding on, you guys foresee you will use the card much?
most of my online spending is for air tix usually, sometimes accommodation usually in local currency, so likely will just use my new dbs live fresh card, since won;t be under the min spend.
but will hold on to the card first since can get annual fee waiver.
ianndaisy
Same to me
My statement closed yesterday, but I didnt get rebate. I called up customer care, she said, wait for next statement.
my statement date is 16. haven't received the Dec. rebate today. but i can see from the estatement the rebate will be $18. i spent $900, seems they used the new term for me...
revhappy
Thanks for pointer. I didn't know it appears like that in the statement. I see it in my statement now. It is 7%.
Sent from Xiaomi REDMI NOTE 4 using GAGT
ah_fu
Between both cards from SC, vpost and unlimited card, which should i cancel as they have almost similar feature?
Trazora
I supposed u meant spree card when you mentioned vpost card. It depends, spree is better for vpost, online and paywave(although dbs visa debit 5% rebate is better); unlimited better for offline spending (below $3000, if not mamhatten card is better), both without min spending. No harm to keep both as there should be no issue asking for fee waiver.
Justicar
The Spree T&S abit confusing. Do I get rebate for monthly handphone and internet bills?
cryn79
Hi Justicar,
You will get rebate for handphone and internet bills.
The % rebate determines via which payment mode was it done.
silverbomb
my final old t&c spend had a hiccup, rebate was lesser than what i normally get.
called in and they will manually raise the adjustment. do double check to see if your rebate is correct for this last cycle.
