Should WE talk about ROOT Note 3
vaxvms
actually if u know wat u doing is quite safe
linux vali hard to crashed, normally user problem
so read and read instruction b4 rooting :)
lumpyme
cannot stand how hot my phone gets during a short session of coc and total conquest
went ahead to root and installed setcpu, encountered problems with setcpu
went to play store to download an alternative, down clocked my phone to 1ghz from 2.3ghz
the game now runs fine and the phone doesn't get so hot anymore
battery life doesn't seem to have improved though, battery caster still reports 4hrs till 0%
Syraxius
You do not actually need to root to mess with the phone's CPU governor. By default, you can actually set it to use Conservative governor (similar to Smartass) by enabling "Power saving mode" in your settings. Conservative governor will downclock your phone to 300Mhz when your screen is off, and only incrementally increase your CPU when your screen is on and when it's required. There is negligible performance impact from that.
Vulpix
Moderator
Moderator
Once you trigger Knox you can forget about warranty. I think this is something like an efuse Motorola puts in their phones.
vaxvms
realise so many bloatwares....think the most for all N's
how to not root ..............
test the phone hardware /software for 1 wk first before diving in
ferr4ri
anybody rooted and unable to rcv the OTA update?
How do you plan to get the updates?
walkingcorpse
hearsay root_de_la_vega.zip from xda can prevent trigger 0x1, don't know how true is it. camping for n9005 ones.
wilflare
I wanna do this too...
and use greenify...
