[SIC] Engine oil promo
trex101
Mobil 1 is their 2nd tier product, might as well try Mobil 1st tier product Mobil 5w30EP(Extended Performance). Mobil EP range is their best products with the highest amount of anti-wear, friction modifying and engine protection technology.
emitchan
how much per bottle roughly?
how often to change EO for u guys? is it 10k km or 6 months, or 10k km or 12 months?
trex101
$15/quart for Mobil EP. It's 1yr or 10k km whichever come 1st but this EP oil is design to go 24k km. Unless you are doing sale which travel alot, if not 10k km is a good number to remember.
Expert
i am looking for performance oil that can stand heat.
currently on Elf 5w40 fully syn, but my oil temp rise very fast and high when i whack.. :sad: :(
emitchan
how come will rise very fast one, yr coolant is it proper? i drive 2 hrs also no see big change in temp
Expert
water temp always stable at 85-90 degrees.
oil temp normal driving is 95-100 degrees. But when i keep redlining or travelling at 150-170km/h, my oil temp will climb steadily to 110 degrees. if whack longer or higher, normally can goes up to 120 degrees..:(
i have this feeling something is wrong with my engine oil passage liao..
-dixie-
Giant Vivocity is having promotion for Mobil EO at S$25 for 2 quarts, ranging from 0w30 to 15w50. Schnell 5w40 is available at S$24.99 for 4L~~
Lawrence O
Nvr state where to collect? or buy?
Bought before, they dont hv a physical store so dont need to pay rental and pass costs to consumers.
Got to liaise with the guy and meet somewhere convenient for both, normally in AMK or Bishan or Serangoon or Hougang etc. Can say prices are definitely cheaper than workshops.
trex101
amk hub ntuc sale Shell 5w40 89.90...dunno cheap nt
If you are after quality fully synthetic products, then you can get it cheaper if you know where to source.
Castrol Syntec 5w40 ($64/4 quart), Pennzoil Ultra 5w40 Euro ($64/4 quart), Quaker State UD 5w40 ($54/4 quart) or Eneos 5w40 ($52/4 quart). All fully syn engine oil and meet API & ACEA certification and certain manufacturer spec.
