SIMBA Fibre Broadband
Teo Ming Ern
1) I will say Starhub 5Gbps offer at S$29.55 per month with ONT is better than SIMBA 10Gbps. Just my personal opionion, but you can take a look at the Singapore ISP Comparison thread for the reasons why I consider SIMBA as not the best choce for either average user (lack support) or power users (CGNAT).
2) No need to change, just go with Starhub 5Gbps offer. Then get either TP-Link EB810v (S$360) or HB710 (S$192) from Starhub.
Singapore ISP COmparison thread: including the links to the special offer and the notes.
https://forums.hardwarezone.com.sg/threads/singapore-isp-comparisons.6665380/
3) Please go to the Starhub 5Gbps thread for more information. Existing users may have some difficulty to subscribe to the 5Gbps offer as it is meant for new users. But Starhub allows existing users to sign up as new user and cancel the existing plan on the day of the installation. You can see the following thread is very popular now.
https://forums.hardwarezone.com.sg/threads/starhub-ultraspeed-5gbps-plan-launched.7024290/
Thank you very much! Basically I have less than a year left on my contract... I guess I just call Starhub and ask for this offer if they want my business lar... for existing customer for me, it's basically cost-free for them.... I just pick up the new ONT and plug in, and return the old one... they do their stuff backend and I'm all set, no?
sglandscape
Nope, you cannot just plug in the ONT yourself. The fibre port has to be first activated for XGSPON use, usually they'll need to measure the signal on the port to confirm it has been lit and has decent SNR. Only then they send a hubtrooper to install the ONT, which appears to require activation manually via the superadmin account.
As to why the process is so convoluted,🤷
tewem
If StarHub doesn’t budge, you can always sign up with Simba.
For your basic needs, the Simba plan is quite suitable.
Since you don’t need to host websites or use old IP cameras that require port forwarding (which could be an issue), there’s no need to worry.
However, if you decide to subscribe to the Simba plan, you might need to perform a factory reset or a hard reset using the button at the back of your router. This is because the Simba ONT device is a terminal, and your router needs to function as a DHCP server to auto-assign IP addresses. This will reset the router to "Wireless Router" mode instead of "Access Point" mode. Alternatively, you can also change the mode from "Access Point" to "Wireless Router" through the Admin page of your router.
(This step is necessary only if your current StarHub plan uses an ONR and not an ONT. If you are using an ONT, you can ignore this step.)
In Access Point (AP) mode, a router generally does not function as a DHCP server. When a router is configured in AP mode, it disables its own DHCP server and relies on the main router or gateway in the network to assign IP addresses. The AP primarily extends the network's wireless coverage without managing IP address allocation.
Not going to happen. Starhub will not waive the termination fee in this case as you still have quite some time with your existing contract. Take note the Starhub 5Gbps special offer at S$29.55 per month is meant for new users. For existing users with their contract nearly finished, Starhub allows you to sign up as new user and then cancel the old plan on the same day. In that case, Starhub can waiver the termination charges and other charges. Not in your case.
By the way, it is the same for other ISPs if you want to upgrade to new plans with existing contract in place --> most of them do not allow that, at least for Starhub/M1/MR. I believe it is the same for Singtel/WC. VQ is an exception. SIMBA 2.5Gbps to 10G upgrade is another exception.
In your case, it does not make sense to look at other ISPs like SIMBA now either. It is too early. You have to wait for your existing contract to nearly finish before looking for new Fibre internet plans.
Teo Ming Ern
Ok boss... got it!
Teo Ming Ern
Thanks bro... one of the Linksys EA-8100 acts as a wireless router (in Hall) while other is acting as a AP (in study)... so for me, I just need to replace the ONT and everything will work as normal...
Teo Ming Ern
Yes I know right... perhaps it's due to security so that no one can just buy an ONT and tap into their broadband and tv services without authorization lor...
luei74
Just activated for 2nd port for Simba, bottleneck speed by my 3 years old GB B450 Aorus Pro mobo.
tewem
I got around the same speed as yours.
My desktop PC network card only can support up to 1Gbps and my old Asus RT-N56U router.
luei74
That's good for the time being, I'm using Asus TX-AX6000, theoretically should be able to get ~2.5GBPS, still wondering should I get the 2.5GB or the 10GB USBC-Adapter to try.....or
wait for my next PC upgrade
abrams75
I just gotten simba 10gb to fixed up the connection today. My Router they will help you setup foc.. so far not bad for the monthly price of $29.90. Well will have to observe for consistency thought...
gregory_choo
ping time too long
CCCustom
2. Starhub 5Gbps offer at S$29.55, with XGS-PON ONT -- you have to get your own router.
https://www.starhub.com/personal/st...speed-5gbps-ont-at-2955_ultraspeed-5gbps.html
The ONT promotion will mean you buy your own router (for users who do not like to use ONR). This offer is also of very good value, especailly since you can get TP-Link HB710 from Starhub at S$192 or TP-Link EB810v at S$360. TP-Link HB710 and EB810v are both service provider models but it should not be an issue if you stay with Starhub.
You can of course get your own router as well.
Boss, I am currently on M1 Broadband 1Gbps contract expiring end of the month … my contract was $3x for can’t remember how many months, then $40.65/month thereafter till end of contract.
I am running Asus XD6 Mesh x2 units currently with wired backhaul.
I need home phone line though … Simba doesn’t provide yes? M1’s home phone line is provided for free with the broadband plan … Starhub still need to pay yes? But all in Starhub would still be cheaper for the same terms even after include the home phone line charge?
Or do you have a better recommendation?
I reckon you can just buy the network card that can support up to 10 Gbps likely is PCI-E slot.
I'm looking at this link, there are 2 options: 2.5 Gbps ($35) or 10 Gbps (about $77)
https://www.amazon.sg/TP-Link-10Gbp...959d213332b9fe9a53d4d2faefb&gad_source=1&th=1
FYI, TP-Link TX401and Asus XG-C100C are the two most notorious PCIe 10G adpater in this forum, especially under Windows. If you can, get Intel chipset.
More info:
https://forums.hardwarezone.com.sg/threads/5gbe-and-beyond-ethernet-adapters.7068236/
PCI-E adapters using Marvell AQC107/AQC113C chipset may have issues under Windows.
TP-Link TX401and Asus XG-C100C are the most notorious 10G network adapters in this forum under Windows. Both are using Marvell AQC107/AQC113C chipset. Some users have to reinstall Windows to get the right speed.
They are usually fine under Linux. So I will say it is partially Windows problem, partially Marvell problem.
1) I think you have got the things right already.
SIMBA does not provide digital voice. Starhub digital voice is not free at S$2.14 per month.
2) For more discussions on Starhub 5Gbps offer, please go to Starhub 5Gbps thread and not using this SIMBA thread.
3) If M1 6Gbps plan is available for you, that is another good option. Please go to M1 thread to have further discussions and not to use this SIMBA thread.
You can get M1 6Gbps with two units of Asus ZenWiFi BT10 at S$59.90 per month, then you can sell one or two units of ZenWiFi BT10 to lower the effective price, if you are wiling to go with this route.
Original price
M1 6Gbps plan with a pair of Asus ZenWiFi at S$59.90 per month.
M1 10Gbps plan with a pair of Asus ZenWiFi at S$63.90 per month.
Selling one unit at S$400
M1 6Gbps plan with one Asus ZenWiFi, effective price at S$43.23 per month.
M1 10Gbps plan with one Asus ZenWiFi, effective price at S$47.23 per month.
Selling two units at S$800 total
M1 6Gbps no-frills plan, effective price at S$26.57 per month.
M1 10Gbps no-frills plan, effective price at S$30.57 per month.
Selling two units at S$720 toal (if the price drops in the future)
M1 6Gbps no-frills plan, effective price at S$29.90 per month.
M1 10Gbps no-frills plan, effective price at S$33.90 per month.
Jimmmmm
SIMBA does not offer static IPv4 add-on. What is the use case here?
SIMBA provides IPv6 support (at least for the 10Gbps plan). That may help some use cases.
For remote access, you can also try things like Tailscale and Zerotier (or similar things).
Hi I am having issue that says the same thing. ISP’s DHCP does not function properly. I have done all the steps but to no avail. @xiaofan can help please since you are the expert here.
What is your router and what is your previous ISP?
I will suggest you factory reset the router and set up again if you switch from other ISP (non Singtel).
Singtel issued routers (Arcadyan, Askey or Airties) can not be used with SIMBA (or other ISPs with ONT) as they have built-in Singtel VLAN which cannnot be disabled.
Jimmmmm
Sorry no idea. I will suggest you factory reset the router and set up again.
Yes did the reset on the router. Problem still persists. Does the cable from ONT from SIMBA which written 10g LAN can be connected to WAN on router?
