SIMBA Fibre Broadband
Yup, I am not going to buy the Eero router, I may ponder to go for Asus AX53U or BE58U router.
Using SIMBA 10Gbps plan with RT-AX53U (lowest end Asus WiFi 6 router) --> worse than using existing 1Gbps plan with a better router.
Just my personal opionion: Starhub has better support and not using CGNAT.
1) SIMBA 10Gbps plan + cheaper 1G/2.5G capable router less than S$200 < Starhub 5Gbps plan at S$29.55 per month offer, ONT option + the same cheaper 1G/2.5G capable router less than S$200
2) SIMBA 10Gbps plan + cheaper 1G/2.5G capable router less than S$200 < Starhub 5Gbps plan at S$29.55 per month offer, ONT option + HB710 at S$192 (dual 10G ports, triband BE18000).
I may be biased against SIMBA/WC/Singtel, but you can check out my reasoning here (just the posts in the first page will do) and you can come out with your own conclusion.
https://forums.hardwarezone.com.sg/threads/singapore-isp-comparisons.6665380/
There are two good offers from Starhub if you do not know yet.
1. Starhub 5Gbps offer at S$29.55, with Nokia XS-2426X-A ONR
https://www.starhub.com/personal/st...speed-5gbps-onr-at-2955_ultraspeed-5gbps.html
You can consider the Nokia XS-2426X-A ONR as a 10G capable wireless router (AX6000, with one 10G LAN port and three 1G LAN ports). You also get a free Nokia Beacon 2 (1G capable only as a free mesh node.
This has superb value for average users who do not mind using ONR and do not want to spend more money to get new wireless routers. If you need more mesh nodes, you can still get extra Nokia Beacon 2 node at cheap price from Carousell if required.
2. Starhub 5Gbps offer at S$29.55, with XGS-PON ONT -- you have to get your own router.
https://www.starhub.com/personal/st...speed-5gbps-ont-at-2955_ultraspeed-5gbps.html
The ONT promotion will mean you buy your own router (for users who do not like to use ONR). This offer is also of very good value, especailly since you can get TP-Link HB710 from Starhub at S$192 or TP-Link EB810v at S$360. TP-Link HB710 and EB810v are both service provider models but it should not be an issue if you stay with Starhub.
You can of course get your own router as well.
tewem
Haha, xiaofan is a Starhub promotor. =)
tewem
I want to avoid ONR and one of the lowest-price plans.
I just trying Simba Broadband as I'm on Simba's Sim-only plan. =)
That is because the Starhub 5Gbps offer at S$29.55 per month is reallly good compared to other plans.
I am a long term Singtel broadband user (from Feb 2012 to now) and I am still using Singtel 5Gbps plan as my main line (and not cost effective at S$49.90 per momth because there was no good offer from Singtel at the recontract time in August 2024).
I am also a long term Starhub broadband user (from early 2005 to now) and I am still using Starhub 500Mbps as a secondary line (at S$30.46 per month, out of contract since Sept 2020). I am lazy to upgrade the Starhub 500 Mbps line to 5Gbps as there is a bit of hassle to get the offer for existing users, and 500Mbps plan is good enough for my use case.
Still from the following thread you can see I do not recommend Singtel to new users. I will mostly recommend Stathub and M1 to new users. But of course every one has its own use cases and preferences -- so the preferred ISP may be different. Still it is good to carry out the comparisons before deciding.
The offer from Starhub I mentioned for comparison with SIMBA 10Gbps is the ONT option.
But indeed every one will have different use cases and then the best plan may be different.
Still many average users are attracted to SIMBA without knowing the catches as mentioned before. Many of them may prefer to get ISP support when needed -- SIMBA may not be a good choice then.
8. More about SIMBA as an ISP.
Main issues now for SIMBA, at least from the reports, are the following
1) Stability issue
2) Lack of support
3) Bad connection to Singtel and maybe Starhub. Quite some SG websites and services are hosted on Singtel/Starhub network. There seem to be improvements though.
Bad routing to China -- but this may only affect some customers.
4) Clear documentation to mention the router to be used. SIMBA does offer Amazon eero Max 7 at discounter price of S$399.
5) No digital voice -- only affected some users. May not be an issue for many users.
6) CGNAT without Static IPv4 add-on. SIMBA 10Gbps has native IPv6 which may help but it may still be an issue for those want to have a public IPv4 address. You can refer to the earlier discussion about CGNAT in this post.
#1 and #2 are the main problems I can not recommend SIMBA to average users as of now.
Power users know their use cases well -- so it is usually not an issue to go with their choice of ISPs. But I would not recommend power users to go for SIMBA either because of #3 and #6.
3. Issue with CGNAT (MR, VQ and SIMBA) and workarounds
https://forums.hardwarezone.com.sg/threads/myrepublic-fibre-part-5.4981088/page-340#post-149246011
Majority of users will be okay with CGNAT but some users get affected (eg: cannot do port forwarding or hosting services).
VQ/MR provide static IPv4 add-on for those who hit the limit of CGNAT.
Unfortunately SIMBA does not have that add-on. It provides public IPv6 for 10Gbps plan users as a potential work-around but not able to sort out all issues.
https://en.wikipedia.org/wiki/Carrier-grade_NAT
  • Carrier-grade NAT usually prevents the ISP customers from using port forwarding, because the network address translation (NAT) is usually implemented by mapping ports of the NAT devices in the network to other ports in the external interface. This is done so the router will be able to map the responses to the correct device; in carrier-grade NAT networks, even though the router at the consumer end might be configured for port forwarding, the "master router" of the ISP, which runs the CGN, will block this port forwarding because the actual port would not be the port configured by the consumer.[7] In order to overcome the former disadvantage, the Port Control Protocol (PCP) has been standardized in the RFC 6887.
  • In cases of banning traffic based on IP addresses, a system might block the traffic of a spamming user by banning the user's IP address. If that user happens to be behind carrier-grade NAT, other users sharing the same public address with the spammer will be inadvertently blocked.[7] This can create problems for forum and wiki administrators attempting to address disruptive actions of a single malicious user sharing an IP address with legitimate users.
yes, I collected the ONT and installed myself. Its not hard to install. ;)
As mentioned I retained my Singtel service on a rolling month by month. When I am satisfied that Simba is delivering properly I will cancel my Singtel service and yes I will need to return their equipment.
Singtel used to require the return of Singtel ONR (nut not ONT). Now I believe Singtel does not require you to return the ONT/ONR (and wireless router) if you terminate the service after contract expires. But of course it is better to confirm with Singtel first.
mooncake52
Yes, I was ready to return their 1 Gbs ONR but they told me I dun need to when I cancelled my service. Oh well, not much value to them anyway, 1Gbs is dated kit.
TickTechToe
Yes, because with the ONT that Simba supplies you also need to have a device that can act as a DHCP server. This is what you activated when you changed the mode of your original router. Before that your DCHP service was provided by your ONR.
Actually this can be naughty trick by Simba to those not technically inclined by advertising a rock bottom priced 10Gbs plan. I think many people don't have a 10Gbs router that is needed with Simba's ONT. People then have to go to Simba and buy their Eero 7 max router which is priced at $399. They then realise that other plans ie from Singtel which provide the 10Gbs router , albeit at a higher monthly instalment cost are not such bad deals after all.
Hi mooncake52,
I am currently using MyRepublic 1Gbps plan and thinking of switching to Simba 10 Gbps plan. My router is a very old model Asus RT-N15U Wireless N 300 Mbps Gagabit Router, which I signed up with MyRepublic more than 10 years ago. If I switched to Simba 10 Gbps plan, can i use back my old router? I am mostly using wired LAN connection for my laptop/desktop, as for wifi is mostly for my guests... so wifi speed is not a big concern for me.. Do I need to buy new router?
phayze
Since you using singtel as main, you can cancel the 500Mbps and sign up as new for 5Gbps. You save $0.91/mth and have 10 times the bandwidth.
mooncake52
Hi mooncake52,
Unlikely you can use back old router. You need a router capable of 10Gbs speeds. If I recall, MR offers a 10Gbs plan with an ONR for an attractive price. Check it out.
Haha, that is not my use case...
But in the end, I may upgrade when I feel the need, now that I have tested HB710 and it seems to be well worth the S$192.
Hi mooncake52,
You may want to upgrade the router due to security concerns. no matter which Fibre Internet plan you choose to go with.
Asus RT-N15U has been out of security updates long ago. In fact Asus has EOLed all AC router as well.
https://www.asus.com/event/network/eol-product/
tewem
Hi mooncake52,
There shouldn’t be any issues, but you won’t achieve the maximum speed of up to 10Gbps. Additionally, security is another important consideration, as older routers tend to have less robust security features.
It’s up to you whether you prefer Simba’s 10.0 Gbps plan at $29.99 or StarHub’s ONT 5.0 Gbps plan, which is priced at $29.55.
I just tested my download and upload speeds, considering that I’m still using my old router (Asus RT-N56U), which was previously bundled by M1. Additionally, my desktop PC Network card is capped at 1.0 Gbps. I recently upgraded my network cable to a Cat 7 cable, and my connection is via LAN to the desktop, not wireless.
Simba 10.0 GBps plan
Download speed: 945.45 Mbps
Upload speed: 940.54 Mbps
tewem
I think you should upgrade to Starhub 5.0 Gbps plan as it is more cost-effective. The extra savings you can donate to charity are also better than spending the extra money to pay for Singtel broadband plan. Maybe u can get another family member to sign up on your behalf if it is that hassle or rather, u sign up the new Starhub 5.0 Gpbs plan, thereafter, u terminate the 500Mbps plan.
Just my 2 cents' worth. =)
TickTechToe
Thanks for your input. Anyway I keep seeing Starhub 5.0 Gbps $29.99 in this thread, but I went to their website, I didn't see it. I only saw 2Gbps $39.00, 5Gbps $45.00 and 10Gbps $$69.95
Check out the "Singapore ISP Comparisons" thread to find out the two "hidden links" promotion: Starhub 5Gbps offer at S$29.55 per month (not S$29.90), one offer with ONR, the other offer with ONT.
You just need to read the first page posts of the above thread.
SingTel has many hidden link promotions, Starhub has two hidden link promotions now.
tewem
Thanks for your input. Anyway I keep seeing Starhub 5.0 Gbps $29.55 in this thread, but I went to their website, I didn't see it. I only saw 2Gbps $39.00, 5Gbps $45.00 and 10Gbps $$69.95
Check out Xiaofan’s tips above—there’s a hidden deal from Starhub that’s a pretty sweet offer. Don’t miss out! I prefer the ONT offer rather than the ONR offer - personal preference as I will have more functions of my router than using ONR which restricts my router's capabilities to just an access point.
Teo Ming Ern
Xiaofan bro, need some help from you...
Currently I'm on am old Starhub Broadband plan of 1 Gbps at $45 per month... contract is expiring only next year, that is Oct 2025... I'm still usinga pair of the old D-Link EA-8100 routers to form a network... my bedrooms are occluded from the main router in the hall, mine is HDB but not BTO... so older flat...
I was quite attracted by the SIMBA 10 Gbps offer. But after reading the earlier posts you put up, I have second thoughts...
Some queries:
1. Would it be better to stick with Starhub or migrate to SIMBA? In terms of speeds? I usually just surf internet, watch YouTube videos and read emails on my desktop and phones. My wife does Facebook on top of the rest I do... I link my tvs to the network to allow my kids to watch YouTube videos.
2. I think it's time for me to change my routers right? Cos it ain't broke, so I'm not inclined to fix them... I would like some suggestions for cost effective routers - WIFI 6 or 7 is better? Or can I keep my routers and upgrade to the 10 Gbps plan?
My basic objective is to pay less per month and keep the current internet performance or better...
Thank you!
Some queries:
Thank you!
1) I will say Starhub 5Gbps offer at S$29.55 per month with ONT is better than SIMBA 10Gbps. Just my personal opionion, but you can take a look at the Singapore ISP Comparison thread for the reasons why I consider SIMBA as not the best choce for either average user (lack support) or power users (CGNAT).
2) No need to change, just go with Starhub 5Gbps offer. Then get either TP-Link EB810v (S$360) or HB710 (S$192) from Starhub.
Singapore ISP COmparison thread: including the links to the special offer and the notes.
3) Please go to the Starhub 5Gbps thread for more information. Existing users may have some difficulty to subscribe to the 5Gbps offer as it is meant for new users. But Starhub allows existing users to sign up as new user and cancel the existing plan on the day of the installation. You can see the following thread is very popular now.
https://forums.hardwarezone.com.sg/threads/starhub-ultraspeed-5gbps-plan-launched.7024290/
