SIMBA Fibre Broadband
Jimmmmm
What is your router and what is your previous ISP?
I will suggest you factory reset the router and set up again if you switch from other ISP (non Singtel).
Singtel issued routers (Arcadyan, Askey or Airties) can not be used with SIMBA (or other ISPs with ONT) as they have built-in Singtel VLAN which cannnot be disable
Current router is SIMBA and previous was Singtel. Not using any ONR from Singtel and had gotten a used Asus router from brother.
Yes did the reset on the router. Problem still persists. Does the cable from ONT from SIMBA which written 10g LAN can be connected to WAN on router?
Yes.
If you have done the factory reset of the Asus router, then I have no idea.
Jimmmmm
Yes.
Basically what I saw from screen on the router admin page is that there is 0.0.0.0 on WAN IP and Subnet mask column. Are these suppose to be these 0.0.0.0 or there are IP address on it?
Oh no, what normally causes the IP address couldn’t be detected? I have set it to enable mode and automatic.
Try DHCP to see if that works. What is your Asus router?
Potential problems:
1) It could be ONT problem or Fibre cable problem.
2) Or Ethernet cable problem between the ONT and the Asus router.
3) Wrong WAN port connection
4) Asus router spoiled.
Jimmmmm
Potential problems:
Thanks for the suggestions. Will slowly exclude all the possibilities to see if I can find the source.
tewem
Have you tried connecting directly from the Simba ONT to your desktop PC or notebook?
https://simba.sg/broadband-setup
This step checks if the Simba ONT is working perfectly.
Also once your router is factory-resetted, check the mode if it has been reset to "Wireless Router" or still as "Access Point"?
luei74
Bro what's your Asus router model? Just activated with Asus Tx-Ax6000 few days ago, it is automatically set-up without any issue.
Jimmmmm
Just an old type of Asus router to test it out before buying a good one. Will try out Ax6000 since you’re able to set up with no issue.
luei74
I'm using the "ASUS Router" App to set it up. It's pretty straight forward process.
After that checking for the LAN IP, my IP ish ==> 192.168. two digit.1 🙏 🙏
Jimmmmm
Guys, guess what, I have 2 FTP ports (port 1 and port 2) and I tried the other one (from port 1 to 2) and that is the correct port. LMAO. This was the easy one but I didn’t manage to check on it. Anyway lesson learnt. Thanks guys for all the suggestions and Xiaofan that he was telling me to exclude all the possibilities.
longshine
Hi guys, I am currently on the simba 2.5G @$20/mth and the contract will be due coming March.
Do you guys know what will be the charges after March if I would like to stay on 2.5G ?
Anyone has the same scenario as me ?
Thanks.
weiess
Thanks.
https://simba.sg/static/media/CISBroadband.bb9bbd66.pdf
4. Conversion of 2.5Gbps Customer(s) to 10Gbps
4.4. In the event that the Customer does not agree to convert from their existing 2.5Gbps to
SIMBA’s 10Gbps Services upon the conclusion of their Minimum Contract Period, the
Customer’s 2.5Gbps Services shall be terminated and this clause shall represent requisite
notice to the Customer vis-à-vis termination.
ambrosiaapples
SIMBA - my experience ... am not tech savvy
31 Dec - signed-up. Fixed 3 NLT installation dates on 8 & 9 Jan. SIMBA replied NLT delayed till 16 Jan
1 Jan - collected ONT and cables
2 Jan - NLT called saying can install on 3 Jan
3 Jan - NLT activated port 2 (port 1 existing telco)
6 Jan - SIMBA broadband activated and running
Been getting speeds of 2334 (download) and 2366 (upload), limited by my router. Realised only my Intel NUC can keep up with those speeds. Will monitor for a week or so before ending old telco and getting them to free-up port 1.
No regrets thus far. Seamless and installation is actually quite straightforward!
BlueGene
What kind of rubbish reply from Simba support, when i log a service request ticket trying to inform them that i do not want to continue using their 2.5Gbps plan when the 12months period i already paid during sign up coming to end in 2 weeks time...
Dear Customer,
Thank you for reaching out to SIMBA Customer Support.
Please be informed that once your minimum contract period expires, your service will automatically renew. You may choose to continue with the service or terminate it without incurring additional charges. However, termination requires a minimum 35-day notice before the next billing cycle.
Should you require any further assistance or clarification, please do not hesitate to contact us.
gregory_choo
Dear Customer,
did you read the t&c when signing up ?
