SIMBA Fibre Broadband
keenklee
Using wireless (Windows 11 Acer Laptop, Intel AX201 wireless adapter), Singtel 1Gbps plan, ZTE ONT, RT-AX86U router.
No problems with upload speed.
Singtel / US West / 137.20 / 139.74, 264.10ms ping, 27.49ms jitter.
Singtel / US East / 85.29 / 102.41, 234.20ms ping, 22.23ms jitter
Singtel / EU Central / 75.66 / 94.60, 252.70ms ping, 45.19ms jitter
I tried a few times (7:10pm to 7:20pm, 31-Dec-2023) and the results are similar, no issues with upload speed.
IMHO.
Almost all your results are 3-digits. Could it be the plan you're on ? :unsure:
keenklee
i don't know why, but the speed test results can be inconsistent. so please take note!
for example, the US West upload speed i can get around 25Mbit/s ? (latest test)
previously, i wrote it as "StarHub / US West / 410 Mbit/s, 7.42 Mbit/s"...
IMHO.
That is weird. I have to relook at how to conduct more test. Cannot be so inconsistent.
I suspect can be due to timezone difference. :unsure:
cyberet
VQ via wifi.. probably off peak now
US West - DL 309.39 Mbit/s / UL 123.36 Mbit/s / PING 186.00 ms / JITTER 0.92 ms
US East - DL 112.89 Mbit/s / UL 107.94 Mbit/s / PING 221.80 ms / JITTER 1.77 ms
EU Central - DL 113.65 Mbit/s / UL 78.10 Mbit/s / PING 209.70 ms / JITTER 2.42 ms
Today at around 7:25pm. Results are similar but EU Central has slower speed.
Singtel / US West / 124.85 / 163.88
Singtel / US East / 90.29 / 101.94
Singtel / EU Central / 52.23 / 83.04
i1magic
Anybody signed up and have this up and running yet?
So they are going to give only ONT with 2.5Gbps port?
I got a 2.5Gbps switch, so does that means that I connect one cable from the ONT to my 2.5Gbps swtich. From the 2.5Gbps switch, one port connects to my wireless router, then connect another port to my PC that has a 2.5Gbps port. I suppose that my PC's IP address and devices connected to my wireless router will be on different subnet, correct?
Like that, my PC will get full 2.5Gbps speed but for the wireless, will be up to 1Gbps max, correct?
I got a wireless MFP connected to my wireless router, with the above setup, can I still be able to print via this MFP?
yosemi
simba need to extend this to the north where most of population were for load test :cool:
weiess
don't think they want to rush it..
scarly got any major hiccups, they won't have the manpower to deal with it.
also will kena from IMDA for any service disruptions.
No, you need to have a 2.5G capable router before the 2.5G switch.
SIMBA gives you an ONT, not an ONR.
alextoh76
Hi all.
Already on Simba. But I kana downtime. 😅
4/2/24 ,1230am-130am , east side - Changi.
Anyone kana? Will ask Simba for the reason.
Good to consolidate so tat you can use the data collected to cancel contract if necessary (provided legally possible nevertheless)
luei74
Hi all.
Can help to note down in spreadsheet your Simba downtime for Jan and Feb Bro? Hopefully this is the only one downtime for chiu 🙏🙏
i1magic
ONT means I can use any router correct?
I am using Xiaomi AX3600 router, really very good router, I don't really want to change leh.
StyL3-Ivan
Since SIMBA only give ONT, anyone tested using Singtel Linksys router? Also SIMBA got bandwidth throttle?
i1magic
I will need to get a Wireless router that has 2 x 2.5Gbps port correct?
Which TP-Link wireless router has 2 x 2.5Gbps port?
Apparatus
Can try ASUS ZenWiFi Pro XT12 (WiFi 6) or ET12 (WiFi 6e)
Each has 1x WAN(2.5G) and 1x WAN/LAN(2.5G) ports
kappak
Xiaomi be7000 4x2.5gbps port
Sgd160+ from taobao
Buy more to mesh is possible
S23u can reach 10xxMbps
Next to main roucter can reach 16xxMbps
