LongBigBronzeElephantFish
- Jan 2, 2012
Thanks bro!
Sure! may wan to try video pro.. their packages is quite attractive.
Is it okay if i just tell them the budget to build the simple rig? Usually how long it will takes maximum?
Try to ask for recommendations here first. Firstly, the shops may not know their stuff well. Secondly, they can't keep track of all the specifications of all products (since they handle such a wide range of products) so they may not be able to give you the best recommendation. Thridly, not all shops can be trusted...
Duration depends on if got anymore people before you. But shouldn't take very long... (Not very sure myself since I DIY the assembling)
Cheers! =)
