Sony 1000xm3
Bababah
Sony replaced my set recently. It was just about 2 months old. The tickering sound on the right cup was unbearable to the point of little appreciation when I'm in public transport.
So far replacement set fixed the issue. Only time can tell...
mp4005 help
Suspended
Not yet out for xm3 walao you made me happy for a moment there.
Hopefully new earpads can make the xm3 less of a earmuff for cold weather
Should be soon lah. Haha.
Read good reviews about them. Most experienced better comfort especially those with big ears.
They also do frequencies testing and they have charts comparing stock versus their different ear pads.
chesterqw
Anyone using this for gym? Afraid might spoil if Kean sweat. Comments?
I never use it for gym, but I would think in ears would be more suitable for gym usage.
In addition, the 1000xm3 can be used as earmuffs in winter because they trap heat really well, so using in gym would probably cause your ears to become red hot
mp4005 help
Suspended
i m using xm2, it gets hot in abt 1hr, so do these ear pads help?
Is the Suede washable?
Not sure. Maybe can email the company or read the reviews on mass drop.
The noise cancelling issue being not as good. I don't really notice the big difference as some of them highlighted.
But it is more comfortable for sure.
evq
Just hooted the Suede version for my XM2. Cant wait for it
RSKeisuke
How's the suede compared to synthetic leather in terms of comfort and passive noise insulation?
The earcups on my xm3 do not look like they can last past 12 months to be honest... Esp in our climate
Posted from PCWX using Motorola StarTac
evq
there're reviews each claiming both are better than the originals, so far, only one review said he got both leather & Suede, he will use his leather mainly. Probably he prefers the leather.
For me, i chose Suede cos for our weather, leather probably not a gd choice. my only concern will suede difficult to clean? I emailed them if suede can be washed, no reply.
RSKeisuke
Does the suede earcups seal as well in terms of noise insulation?
I think there are suede shoe cleaners but i do not know will they stain... :o
evq
I just ordered from Amazon. have to wait till i got it before i can comment.
RSKeisuke
Sorry if i keep asking about the passive noise insulation... But i saw many commented about them poorer than the original...
evq
i will update herer after i got them & tested.
