Sony 1000xm3
mp4005 help
Suspended
Sorry if i keep asking about the passive noise insulation... But i saw many commented about them poorer than the original...
Posted from PCWX using Motorola StarTac
I think it depends on your ear size. I just used them for my flight. Insulation and noise cancellation felt the same to me. Used them on a bus before. Same.
But that is my opinion and my set.
Adelyte
evq
Just arrived from Amazon. Ordered on 15th Feb.
Do take note, mine is XM2.
Left is stock, Right is Dekoni Audio Suede Material.
They are bigger & deeper.
Right is stock.
Have not thoroughly tested, so my first impression when i put it on, is..... Wow!! Can feel the diff liao.
First 10min of use, dont feel uncomfortable vs the original Sony cups. I will feel a bit uncomfortable with the stock cups just after 5-10min. Will have to adjust & let some air in. after an hour, will definitely need to wipe my ears & the cups. With these new cups, dont feel the need yet.
As for passive sound canceling, so far, i dont feel any differences. I only tested indoor.
RSKeisuke
Anyone updated their xm3 fw to 4.1.1? Is it really that bad?
evq
Google it... Some claimed the anc becomes poorer after that
Yeah I do notice a bit. And encountered some intermittent cut off of connection.
RSKeisuke
Received it last night! Very happy with it so far.
:s12:
Better not upgrade to new firmware right?
I stopped mine at version 2.0.0.
Reading all the 4.1.1 horror stories, i think i better not
edit: :mad: just realised the app updated mine without asking me! damn it.. the anc really gotten worse :(
miketanct
:eek:
How can it be?
The app on my phone has a More Info bar which expands to show details of the new firmware. I clicked "Later" button after reading it so it doesn't update.
Maybe you clicked the "OK" button?
evq
Yeah lor, the anc not as good now. And the app causing intermittent beeps, sometimes even turning off the NC. Now I uninstall the app. Solved the beeps issue but the anc not as good. Bass also softer.
