Sony Days 2015
nomoney25
Sony guy brought the free low profile mount and it's over in 20 mins. 1 man job. I have marked out the spot before he came.
Nothing eventful.
The power a bit shorter than I would have expected. Considering that my center of tv is barely 1 meter from the floor.
As long your eye view is toward the centre of the screen or the screen is slighly higher your eye view. That fine.
killerl
Got any software recommend to run high bit h246 mkv? I tried both Kodi and mx player with sw decode, both run 10bit h246 choppily.
dragonsballz
me thinking to buy the 50W800C
how many 3D glasses in total?
2 glasses in box and another 2 given as free gifts?
meaning total is 4?
or just 2 glasses as free gift...as there are none in the box?
dragonsballz
compass point point best,50W800C 1449.
Free delivery, free 50 choice voucher, free hdmi, wall mount, additional 2 3d glasses, and 1 flip remote.
Just called Compass Point Best Denki after realized the 'cheapest' price for the 50W800C, as reference above.
They told me price of TV is $1549 (TV only)..delivery, mounting is chargeable...
So skip that..
Tristan2009
i have used the vpn to access the x85c. now i can see the usa apps like bloomberg. but i can't see the netflix app in the google play store nor anywhere else.
must i update the firmware? i am from singapore, so the original firmware has no updates. do i need to do anything like change the location on the tv, or download the isa firmware (now that i am suppose to be on a usa server)
is the latest firmware in US stable?
ralliart12
Nothing eventful.
The power cable a bit shorter than I would have expected. Considering that my center of tv is barely 1 meter from the floor.
Got mine mounted recently as well; seems to be challenging connecting a LAN cable to this TV unless I lift it off the mount temporarily...
Tristan2009
I think it will be the same with most other tv unless you use full motion mounts which I didn't because I wanted a more flushed look.
I got the wires ready in their respective places before the mounting is done
congster2
Not sure what you mean by U.S. Firmware. My TV is a w904A and I'm using SmartDNS so after configuring it on the TV, I'm able to access the Sony playstore to download the Netflix app after refreshing Internet content.
The newer android based TVs are reported to have the Netflix app (based on the article in HWZ, no less) hence you should be able to find it if the vpn/dns is working properly.
Tristan2009
My vpn is working, I can see stream netflix on the wdlive which is connected to the same router.
Still can't find netflix anywhere in my Sony apps nor play store
