Looking at the 65" X8500c. Anyone know where to get the best deal?
Am also considering the Samsung SUHD JS9000.
Still deciding which to get.
Anyone using 55X8500C.. Is it normal when I on TV. It will always go to the youtube page. I always need to switch to HDMI 2 to see my tv channel.
Possible to set default when I on the TV it goes to HDMI2?
You can try parisilk, their price is lower than mustafa.
The x8500c vs the js9000 is a hugh difference in quality.
If you want to compare with js9000, you might want to consider sony 65 x9300c.
Also thinking of getting Sony 65"X850c(about $49++) or Samsung 65" JU7000 ($41++ with free 40" TV) or LG 65" UF860T ($41++ with free 40" TV). Could not decide which one to get.
They used sanus wall mount for my 75x8500c . Unfortunately. The guy threw off the sanus box before I could remember. Anyone know what is the wall mount model they used.
I asked before at Sony 313 and they told the only difference between between X8500c and X9300c is the super thin bezel, else everything is the same.
Best price I asked for the 65" JS9000 is about $54xx before the trade in of the 40" UHD TV. IF can get at $48xx after trade in, very likely I will go for it.
Did the Sanus wall mount that Sony provided allow for vertical tilting and horizontal alignment fine tuning?
E.g. Sanus VMPL50A
http://www.sanus.com/en_US/products/mounts/vmpl50a/
I removed one such wall mount myself recently. Ya, horizontal alignment can be made. There are fixing screws, one each on the vertical arms that are fixed to the back of the tv set. These screws would be tightened by the installer to the lower "rail" of the bracket that is fixed to the wall. So the strength needed to slide the tv set sideway would depend on how much the screws were tightened.The wall mount look quite exactly from the sanus model u linked with. The installation guy told me i can do horizontal alignment by pulling or pushing by the side but so far i dont tried it.
Thanks, were both TVs recent purchases?...
...Noticed that the 40" mount allows tilting, but the 55" mount doesn't?...
...Does the 55" mount allow for slight backward tilting to give more access to make AV connections while mounted?
I suppose you can ask for the adjustable type to suit your purpose?Thanks, were both TVs recent purchases?
I think you mean the 40" allows semi-permanent tilting adjustment? If so, yes, the 55" doesn't offer the same type of adjustment.
Hello all,
Anyone know what's the main difference between the R and C series? Considering one of the following four, almost $200 difference for the same size
KDL32R500C - $409
KDL40R550C - $649
KDL32W700C - $589
KDL40W700C - $829
