- May 3, 2001
Which location?
It seems that I was mistaken. The problem seems to be my phone. I reseated the sim card and it solved the problem.
Which location?
Yup it’s specific to this scenario. Wife and brother are on GOMO, which also has no VOLTE but they can at least use the 3G to surf while on a voice call. Brother performed a speed test while on GOMO 3G and on a voice call, around 3+Mbps down and 1 Mbps up. Giga unable to load the speed test site. Also unable to load google.com or takes more 20 second to.This problem only applies to the situation where you make a call and use data at the same time ?
Thanks.
Is Giga able to load if you just switch to 3G to surf? If cannot meaning Guga 3G is weak
Activated mine on 1st Oct. I’m aware giga and MVNOs do not have VOLTE. However the 3G on giga while on a call is really unusable, to the extent of can’t load google.com satisfactorily even. It’s really a deal breaker.
Oh man, I thought starhub has volte and hence giga should have. The newer players all can call and hotspot at 4g speed.
Which other new player can VOLTE other than CL and MR?![]()
Refer to my post below your post
But you did not say ALL the new players mah... people say I ask lor...![]()
Just less than 1 month using my new mobile number kena the 1st scam call this afternoon
I think those Virtual Telcos haven't or don't setup the system for ownership issues, that's the bad part.KNN giga sibeh ridiculous.
Although I know the giga does not do transfer of ownership, I thought every telco would at least do that in the case where the account holder is deceased.
I tried to take over my father's account even though I told them my father passed away liao, and still they said it was not possible. And suggested to port those numbers out to another telco to do transfer of ownership. Can u see how ridiculous that is? How am I able to sign up for another telco using my father's name when his NRIC is already cancelled?
Luckily those numbers are just temporary ones and I have not ported in the numbers yet. Really knn.![]()
I think those Virtual Telcos haven't or don't setup the system for ownership issues, that's the bad part.![]()
Time to play the myrepublic card..
