Starhub Giga
sparky3
Can I check, I have just receive the Giga SIM card via delivery.
I am portng over from M1 and want the billing cycle to start on the 1st of Dec..
How should I go about it? When do I activate the SIM card?
And another question is porting over should affect the billing cycle right?
Thanks in advance for your help.
Kiwi8
Deluxe Member
Hopefully u had chosen "Get new number" instead of "Port in number". Cos if u had chosen port in number, it would be done within a day or two of delivery, and u do not get to choose when to activate the card.
So supposing u chose "Get new number", then u can choose to activate the card anytime on 1 Dec, or if u really want to have the time stamp of 1 Dec 0000 hours, then activate around 0000 hours + 10 seconds (to avoid server time sync issues).
Kain999
Going to jump from circles to giga soon. They send the SIM card via normal mail or registered? Cos won't be at home to take mail.
ShinnAsuka
Anyone has any data draining issues using giga? Started using since 20th Nov and I clocked 5gb usage. Android phone btw.
GoodBetterBest
Rollover data. Anyone can help clarify this for me ? Does it mean if I have a 6GB plan, after rollover, the max I can have it 12GB ?
say this month I left 3GB, so next month I will have 9GB.
if month 1 and 2, I have 8GB left at the end of 2nd month, I will have 12GB in month 3.
If so, it says "for another 2 renewal", but it does not matter cause it's already capped at 6GB rollover ?
Anybody know exactly how this thing works ? Thanks !!!!!
What is Free Rollover Data?
Roll over unused data from your giga plan for another 2 renewal cycles, capped at 6GB for the 6GB plan, 45GB for the 45GBplan and 75GB for the 75GB plan, at any point in time.
Roaming data from gigaRoam pass and other extra packs will not be rolled over.
Only giga gives you a second chance to use the data you love. Viva la giga!
Kiwi8
Deluxe Member
Yes u have basically got it right. One can bring over 2 months left over but at most the 1 month allocation. So in the case of 6gb plan can only bring over 6gb from the previous 2 months.
Apex
Unused data only roll over Once.
So
Month A left 5GB
Month B you get 6 GB + Month A rollover(5 GB). GB.
Month C you get 6GB + Month B rollover.
Month D you get 6GB + Month C rollover.
GoodBetterBest
So
Month A left 5GB
Thanks for the info. Great. I was thinking how they program the algo to roll over.
Thanks again !
Kiwi8
Deluxe Member
Actually hor, I also wonder how Month 1's data can ever be brought over to Month 3. Cos surely in Month 2, the roll-over data from Month 1 is surely gonna be used up first before even touching Month 2's allocation.
GoodBetterBest
Not only that. There is a cap on the rollover amt. For me, I'm on 6GB. So max is 12GB == 2 months. I'm not sure about other plans.
That's why I wondered how they quote the algo to rollover. So unless they change the 12GB (2x) cap, then it's 1 month rollover max.
bastero
Anyone port multiple numbers to giga before? I have 2 lines for StarHub, planning to port in to giga but I have to pay delivery fee twice ($2x2) although I chose same delivery slot. Any option to pay for single delivery fee?
kazuki666
Anyone know how this usage alert works? 3GB means what???
Sent from Xiaomi POCOPHONE F1 using GAGT
kazuki666
Means u will be alerted when u use up every 3GB block, I think.
Hmm quite strange settings. I rather they alert me when the usage reach like a certain limit like 80% or 90%...
Gnaijispro
Guys. just to ask a very stupid question. does the $10 6gb plan comes with free outgoing sms and call? as i see the FAQ showing only free incoming call and sms. outgoing call and sms is chargeable per min/sms.
tried contract their cso but to no avail. email them 5 days liao also no single reply from them.
