Starhub Giga
samsocute
First week using giga! plan. Experience 3/10 using iphone xs max. Mostly very lag at town area or woodlands. Apps cant load and giga doesn’t support VoLTE. I was a singtel user for close to 8years till recently contract ended and decided to switch to sim only.
Even thou sim only plans have alot of data but it’s redundant because its too lag. Probably waiting for good number from giga and switch to m1 or singtel sim only.
dngth
Im already on giga. Wanted to port over my parent's existing M1 mobile line to giga.
Any idea if I can add another line to my giga acct and port over my parent M1 number to giga?
Kiwi8
Deluxe Member
Who has the ownership of your parent's line? Your parent or u? If your parent, then u need to transfer the line to u before porting into your giga account.
Jurong640
You should have expected that when you switched from main Singtel to giga which is using Starhub.
You could have switched to Grid, which is using Singtel network.
RLWZ21
As in there will be the word "5G" at the network bar there?
yes:
taken from hwz testing phone:
RLWZ21
i though this was mentioned in quite a number of threads around here that most MNVO does not have VoLTE beside Cricle. and if you want such service, u should consider Singtel on SIM only plan. (i think should have ba)
kazuki666
yes:
Hmm I am using Poco F1. I supposed it doesn't support 5G???
Noob qns. I won't get to use 5G network if I don't have a 5G phone right?
Sent from Xiaomi POCOPHONE F1 using GAGT
RLWZ21
well only recently release flagship phone have 5G. and if u want just buy a supported 5G phone can get 5G
samsocute
Singtel does have sim only plan, but it’s 1year contract basis
samsocute
Heard gomo is also using singel network. But i think VoLTE is important to me, most of the time i play games and on phone calls
007Mi6
Singtel M1 Starhub and TPG all have minimum 1 month contract SIM Only plan.
For Singtel, their SIM only plan without contract is a $20 with 3GB, zero talktime and zero SMS plan with no caller ID
