Starhub Giga
wulunzun
Anyone having problem signing up for a new number or porting-into Giga? I keep getting error after entering my address.
jt2901
Also seem to be having issues atm. Tried using the app and web signups, both no response
Bunbun33
Sim card came on 16th and successfully port over at 12:10am today. So far everything seems ok except for OTP Sms. Thank you Jurong640 for the advice
AndyLau88
Would like to check - my Singtel expires on 19 Nov.
Next billing cycle is from 20 Nov to 19 Dec.
Should I port in my Giga on 19 or 20 Nov?
GoodBetterBest
Isn't the OTP just another SMS ? Any technical reasons why OTP cannot be received ? Woud like to know. Thanks !
sadboy
Read before in this forums that there is some database which need to be updated and it take time to be sync with each sms provider.
If the sms provider database is not updated it will kept sent the SMS to your old provider which result in sms not reaching you.
Once all in sync they will know oh u moved from Telco a to b
kazuki666
For those who curious Giga network. When in CTE tunnels mostly ok, until the last strength coming to Outram
Sent from Xiaomi POCOPHONE F1 using GAGT
Aquarius81
Some did not receive OTP sms at all.
How about those who did receive SMS OTP ? :s11:
Is it 100% everytime you receive the SMS ? Or only sometimes ? :s22:
Kiwi8
Deluxe Member
I am on the giga plan for close to 2 months liao.
So far all the OTPs I had requested were delivered to the number successfully.
ekardo
I know for starhub only certain area have 5G..(mostly in town)..
but dunno if they can differentiate between giga and normal starhub user..
