Starhub Giga
bunegg
I'm sure there are many other kind souls here thats willing to gift.
Sry i max out with 40 codes liao. My limit is the amount I saved from my old plans after switching to GIGA.
ERT
Those already on Giga have until 30 June to save at least 12.8712871287% per month for as many Giga billing cycles as your Giga account goes thru’ till 28 September 2023.
badkham07
Ok I went to check in more details about the gift a line promo.
For convenience I just put what I learnt so far about it.
Promo deadline: Activate before 31 August 23
simply follow the steps below:
1. Login to giga app and select the 10GB plan
2. Select “Keep existing number” and fill in your number transfer details
3. Proceed to verify your customer details
4. Select your preferred delivery timesloy
5. Enter gift code and proceed to check out at $1.
6. Once you receive your giga SIM card, your number will be ported over in the next worki
ng day
yes porting is triggered upon delivery of SIM card. It takes just 1 working day for porting to be successful.
Who can buy gift code:
Only giga customers have the power to gift a giga mobile line. BUT the gift code can be used for all new line sign ups, applicable to both new and existing giga customers.
That means the gift code can be used for your same giga account, but for a new line sign up.
Each gift code can be redeemed only once.
Hi, anyone can help me on this. I am an existing Giga account with a line (Number 1). I have another line (Number 2) with another telco, and I have just bought the giftcode.
My login to the Giga apps is via email address and i signed in with the same account that i am using for Number 1.
I selected "add new line", and after keying in the details (i.e. number 2), it pop up a box and prompt me "To confirm Transfer". I did not see the field to enter the giga gift code up to this point, and decided to just cancel the transfer first (As it mention it is non reversible). Can anyone guide me on where can I enter the code for existing Giga account? Is it after confirming the port in?
Thank you.
sakuraji
Thank you.
Key in at the payment step (last step).
Uacesg
To port out of giga, do I need to inform giga? Or no need to inform as the next telco I'm signing will do all the work?
Thanks in advance
firesong
Deluxe Member
Thanks in advance
You do not have to inform your telco when you port out. The destination telco will inform them, and your current telco (the "donor") will do the necessary terminations automatically once the line has been ported out.
Do not terminate your line before porting out. In any case, if you try to inform your telco, it is possible that some blur CSO may take it as your instruction to terminate, and proceed to terminate your line. If this happens, you lose your number.
So, don't do anything.
Severon
Just wondering if the giga connection is good compared to Gomo and other sim no contract ? thinking of porting from starhub to Giga .
kazuki666
Actually why are there much grievances on Giga? I have been using more than 2 years, turning 3rd this. To be fair, the price is fair for what I get in terms of value for data/calls. Before that I was using the orange and green, honestly they suck in value and poorer in retaining customers.
I have a Simba (TPG) as secondary line for $10. Its slightly inferior, but serves good enough as secondary especially on times I need urgent hotspot for laptop outside.
firesong
Deluxe Member
Reception is location based. So it really depends on where you are 90% of the time: home, in-laws, school, work. place of worship, regular malls, etc... What works for me may not work for you.
The general consensus is, go with the telco that best suits your needs. There are cheap plans so you can always run a test over two months before settling. There are only 4 main networks in Singapore, with the virtual telcos riding on them, so since you're on Singtel's network, you may wish to try out StarHub's, M1's, and TPG's.
firesong
Deluxe Member
Customer retention hasn't been a priority for the past 15, 20, even 25 years since before the millenium. :s13:
If customers expect vouchers and promotions to entice them to stay, they are on the losing end of the negotiation. Vote with your wallet and just go with what works best for you.
Severon
i see ! i more of concern for the consistent network and connection compared to the expensive 50$ plan i have now , but yeah i will try each one till i find one i like . Thanks :D
firesong
Deluxe Member
There's also QCI, so that will affect your experience when there is more congestion (Eg, NDP, Concerts, Chinese New Year in Chinatown, Hari Raya Ramadan bazaar, Christmas shopping at Orchard, etc). More premium plans have higher priority and are not affected by network management algorithms like QCI.
It's not the same as throttling, though to the user it feels throttled.
