i.Singaporean
- Jun 2, 2012
Can anyone confirm to generate new eSIM for transfer is it (still) $1?
Thanks in advance
Thanks in advance
But there's a catch, even though the data, talktime, sms remains the same, it's still consider a change of plan when you upgrade, so any existing data rollover will be reset on your next cycle.got free monthly 4gb roaming data for the $12 plan. go app to upgrade for free.
Is that a legacy plan ? I don't see any $12 plan on giga website atm.got free monthly 4gb roaming data for the $12 plan. go app to upgrade for free.
Nope it's their current 4G 100GB $12 plan. New one comes with additional 4GB roaming dataIs that a legacy plan ? I don't see any $12 plan on giga website atm.
Am I missing something, I don't see it here leh : https://giga.com.sg/mobileNope it's their current 4G 100GB $12 plan. New one comes with additional 4GB roaming data
It's a pop up promotion plan.Am I missing something, I don't see it here leh : https://giga.com.sg/mobile
giga romaing very ma fan, need to manually select U mobile or maxis, cannot set to auto cos cant get any dataWith this free data roaming... do I need to do anything on the app when I travel to Malaysia?
1 selection so difficult ah?giga romaing very ma fan, need to manually select U mobile or maxis, cannot set to auto cos cant get any data
so if I paid before this plan kick in, I'd only get it next payment cycle rite?Nope it's their current 4G 100GB $12 plan. New one comes with additional 4GB roaming data
what do you mean? if auto roam, the phone wont find the network?giga romaing very ma fan, need to manually select U mobile or maxis, cannot set to auto cos cant get any data
wad u mean? difficult as in wldnt auto connect or wad?1 selection so difficult ah?
not sure, but at least this is wat I was told from their mailer - need to select manually instead of auto connectionwhat do you mean? if auto roam, the phone wont find the network?
it was sent to my emailwhat mailer? do you have the link? thanks.
https://giga.com.sg/FAQs_Details.aspx?QuestionId=6601do you have the link?
Giga just recently increased or added monthly roaming to their plans.I'm currently on $10 plan, saw a free upgrade offer but no details of the upgrade, can anyone advise?
Depending on your phone and situation, just waiting for the list of networks to show up could take few minutes.1 selection so difficult ah?
