- Mar 22, 2011
tease people only. just a collab with shopee onlyI thought what big announcement
Otherwise no movements, how to attract attention to GIGA.I thought what big announcement
no such good things. I was thinking for 3 months. Looks like same tactic as gomo.rofl confirmed only for 1 month. On their IG TnC
At least got 5G $19.90 special Shopee plan, now at $11.90 should be 1st month onlyI thought what big announcement
Yes. Pretty bad. I do manual selection of network provider but most of the time I end up buying esim from shopee to use.Anyone experienced spotty or weak network when in JB Malaysia?
Even though showing full bar but sometimes no internet.
Is 10g enough for your long trip and you are sure that you will not top up roaming data? If not I suggest you buy those travel data esim will be cheaper.am travelling on a long holiday to Japan.
Have a singtel company mobile.
Am thinking to sign on Giga 5G esim to make use of their 10G international roaming.
My question is (sorry if this is basic or have been mentioned previously):
1. will it be possible to use esim alongside my company phone line which remains active?
2. cancellation - i really only need it for the trip. Can i subscribe a new line and cancel after the trip without any charges? would be just that one month of subscription?
3. Any better recommendations with other service providers?
4. Thanks in advance for your advice.
Hesitant whether it is sufficient (for 22 days). Please recommend suitable travel ones.Is 10g enough for your long trip and you are sure that you will not top up roaming data? If not I suggest you buy those travel data esim will be cheaper.
Should be possible with most phones nowadays that runs dual SIM, with the usual x1 Physical + x1 eSIM. Sharing your device model might provide better clarity.
If your trip is within a month then yes, will likely be a month charge. Unless it cross the payment cycle of the telco's billing.
There's others that provides Japan roaming like SIMBA, Eight etc. that provides Japan roaming incluided @ $12 & $11.8 respectively.
Believe these are the usual ones that are used when one travels since they provide a decent amount of roaming included. But do note that Eight requires SG activation, while SIMBA possibly might be able to be activated while overseas which might come in useful if you require more data while you are in Japan.
If it's a local SG iPhone 15, then definitely will work with x1 Physical + x1 eSIM.froztheart, thanks.
1. my device model - iphone 15 (presumable ok).
2. sounds good that subscription can be for just one month without penalties when i (can try to) time it within one month.
3. Eight and SImba - will consider them if they offer vast advantage with GB (vs activation intrication)
What is your plan for the line after the trip ?1. Originally thought of signing on 1 new GIGA 5G esim to make use of their 10G international roaming.
And I believe I could further save $6 for referral and $6 for referee for the new line.
6. But as I will be needing to perform banking transactions while overseas, looks like I still may have to switch on my roaming on the singtel line (on my own phone) to receive the verification codes coming off SMS and even if I have hotel wifi?
Line is for this trip only.What is your plan for the line after the trip ?
For one time use can consider Simba/eight/maxx $12 plan, for Simba/eight you also get free voice roaming should you need that.
With any arrangement to use a separate data sim, you will need to turn on roaming or wifi calling on your OTP line to get OTP, otherwise there would not be any connection between your OTP line and the system.
For wifi calling, I know Simba works overseas, M1/Maxx does not, it appears that eight also doesn't.
Not sure about Giga/Starhub/Singtel.
