Starhub Giga
daranic
Roaming is needed cos no network oversees mean no calls or sms. But not related to gigaroam which is for data only.
How to turn roaming on or off on the hp? Only know we can do that for data roaming.
giraffey
M1 gave free roaming subscription when I have the hp plan with them. For Giga is it by default roaming is free?
They only have data roaming. If you require roaming, just stick with the traditional telcos.
angryuser123
If I am existing giga user and change to another Giga plan (eg $18 pop up plan) , will Giga send me a new sim card or I can use my existing sim card?
daranic
Oh dear. That’s another confusion again. If roaming is required to receive sms overseas and Giga does not have, then how do those who reported can receive sms do it?
milanmania2004
Existing giga user here, no problem in receiving SMS while roaming in JB.
Sent from Sony XZ2 H8266 using GAGT
crystalnox
100% confirm using back same sim card. The change of sim card thing was completely false.
xonix
No confusion, stated clearly in their FAQ.
Incoming SMS while roaming = yes in 230 destinations
Outgoing SMS while roaming = no
Incoming Calls while roaming = no
Outgoing Calls while roaming = no
xonix
I switched from the $25 to the $18 dollars plan this month, carry on with existing SIM card.
You are not changing providers, why would it involve switching of sim cards ?
windtreader
Giga referral code
no need for referral codes, already signed up for starhub giga
angryuser123
Tks buddy, somewhere in the thread, someone claimed will have to get a new sm card
x3nor_S
Just want to check. Understand when I switch plans my rollover will be forfeited. New plan will take effect in next billing cycle.
currently my data is 10gb(roll over from last month)+25gb
Question: The current month I will still enjoy 35gb of data till my new plan takes effect in the next cycle right?
jeezycheezy
Planning to port over to giga, anyone know if the data coverage along the NEL line is stable???
twosix
you can check the giga app on your total data allowance for the month.
crystalnox
Everything will only take effect on the next cycle, whatever you have on the current cycle is safe.
XxjohnxX
If you are porting in, there is no need to cancel.
Simply inform the telco you want to switch to that you are porting in and the details (number and current telco) and it will be done within 1-2 working days of receiving SIM card.
Make sure your number is not prepaid, you have no outstanding bill and that number is tied to your NRIC
Hi I can ask u, I have just port over 2day ago why util now can't use data, I have follow the APN settings still same. Please advise
XxjohnxX
Need help I have port over my number to giga two day ago why until now data still not working. I have follow the APN settings, also cant solve. Please advise
