Starhub Giga
ichinisan
At most 12GB. 6GB from your current month and at most 6GB from your previous 2 months.
Thank you for this! For the Giga app, there is no need to login every time you open the app to check on usage right?
HCS_HCS
Those that need referral code, can drop me a PM :)
Seems like they giga! re-enabled their code referral, at an exclusive rates. If anyone needs the $25 plan for just $10 (ie $5 more than their standard promo), can drop me a pm. :s12:
invisible999
Hello everyone,
Considering switching to Giga for my wife. Could you please answer/provide feedback for the following questions:
- Is it possible to port directly Starhub prepaid number to Giga? Any personal experience?
- If switching directly is not possible, then the only alternative is to first switch to $25 SIM only Starhub plan and one month later - switch to Giga, correct?
- Does anyone use Giga in Pasir Panjang area? What reception/signal strength looks like?
- Any experience using Giga on Iphone SE 2?
- Any experience using a mobile hotspot with Giga? Any problems?
Thanks
Currently, my wife uses about 1.5G-2G data per month with no more 30-50min outgoing calls. For this twice per month $10 top-up is required. So Giga looks a better alternative.
George Soros
Nice..thank you.
I just want to use no contract plan for short term.anyone can pm me their referral.?
Intend to sign up on 29aug once my contract finish.
tanchoo1
Hello everyone,
Thanks
No issues with mobile hotspot on giga for both iOS and Android. Just remember to change the APN to giga.
yanfxl
Can I choose the port over date? Billing cycle of my current sim is on 15th of each month.
Thx.
tuntun
When will the activation of SIM start? Will it start once install their temp SIM into handset? I received the sim but slot in to handphone 5 days later means will the activation start on that day i inserted sim?
Jurong640
Yes, it will be activated once you pop the SIM into your phone, and activate via the giga app.
I've signed up for a new number 2 months back, I purposely want the line and billing to be on the 1st of the month.
I receive my SIM on 20th, I put the SIM into phone on 1st and activated it. My billing cycle starts 1st
meekiatah
Hello everyone,
Thanks
Cannot port directly from starhub prepaid to giga. Or, any prepaid to mvno for that matter. You will need to port to postpaid line, then to giga.
Starhub sim only, iirc, do t have contract. Not sure if it's changed. So, technically, you can immediately port out the next day after you port to starhub sim only.
Using giga in bedok mainly and on Android, so can't reply on that. But, no issue with using it as mobile hotspot.
Need referral code, pm me. :)
invisible999
Thanks everyone for replying. Seems moving from Starhub prepaid to Starhub sim-only no contract is the only option.
If anyone has experience using Giga at West Coast/Pasir Panjang area and on Iphone SE2 - please share.
HCS_HCS
I’m staying around West Coast area and using iPhone 11 Pro, signal is good and stable.
PM if need referral code :)
