- Mar 22, 2011
giga no roaming calls? So can I call/sms someone outside Singapore? Do one need to add IDD pack to call overseas like Grid?
The port in option something like this (second row of the menu). So you don't need to sign up and port in at the same time. Port in can be done later.
1. Sign up with new number
2. After received sim card, can wait to activate the sim card. This is to sync billing cycle and time for your convenient.
3. After activate, port in anytime you want. It won't affect the billing cycle. You can port in after your old sim used up all the data/at the end of billing cycle.
thanks v much bro. After you select "port in to giga", is there an option to choose the specific plan for the port-in number? As i will be having 2 numbers with different plans in 1 account.
The extra add ons like 1buck for extra 100mins must be done during sign up? Or can add after use for like after 1-2mths ?
For new/ port in customers onlyI cannot change to the $18 plan just now. They don't allow me
Thank you very much.No need. It is really meant as a ready-to-use booster lor, so whenever u need to add extra talktime, then u buy. But it's up to u I suppose. If u need it all the time, then can buy it every month, otherwise just buy when u need it.
It*********s only for existing $18/20gb users and new/port in users.
All other current giga! users llst.![]()
Very very disappointed with giga that they do this. That's why customers have been porting out of other telcos, because their promotions are not available to existing customers. Now giga is trying its best to piss loyal customers off.
It’s only for existing $18/20gb users and new/port in users.
In my situation, they are rewarding me.
I switched to the $18 plan ever since it was first available and now I'm getting upsized to 40gb![]()
Planning to switch to Giga...
But their robot livedesk not helpful.
Just want to check those using giga and their roaming when u go overseas... besides the 1G data that comes with the roaming add on... can also use your loc al data or only strictly that 1G?
strictly that 1GB add-on
