Starhub Giga
ET_ETs
Hi all
Just to check new sign up user need to pay any registration fee ?? thinking of sign up Giga $18 for 40GB plan Thank. Currently M1 old user :o
d3n
Me also m1 mysim plan user but not switching cos m1 data passport for roaming still better.
Giga u pay $5 for 5 days only 1G
M1 data passport u pay activation fee + country fee... u get whole month using your local data (my current plan got 30G)
Hi all
ET_ETs
Thank for the information but i not using mysim plan my is and old Iphone plan. Thinking switch to cheaper plan. Just call M1 CS and wast told that The M1 $20 my sim only is for new customer only for old user like us if change to my sim only need to play $25 + $5 caller ID total is $30 :(
Kiwi8
Deluxe Member
Guys, can those of u who will be activating your line via the app in the next few days do some screenshots? Remember to blank out your personnel particulars in the picture before posting.
How long will it take to finish the activation steps? Is it activated before APN setup or after APN setup?
bunnypangsai
it will take ard 2 mins? to complete the activation. Once you insert your sim card and connect to wifi + launch giga app, it should be reflected. After that, there will be a video guide on how to modify your apn.
Kiwi8
Deluxe Member
I understand from earlier posts that it is possible to activate the line via the app without inserting the card first rite? Will it be quicker that way? Can set the APN later rite? I wish to time the cycle time to 0000 hours or as close to that as possible. :o
bunnypangsai
i didnt try the method of activating through the app. It's possible to achieve the 0000 reset time by slotting the sim at 235959:s13: and then activate through app asap:s13::s13:
tho you can just track the data usage from the app itself:s22::s22:
Kiwi8
Deluxe Member
Btw can also activate via the giga.com.sg website rite? Cos I saw the same "activate" button via the website too.
Kiwi8
Deluxe Member
Yes you can. Their so called “activation” is just a tap on the button as long as you are on wifi. I did it on 1st of the month 0000
Thank you!
So just to confirm, I just need to tap on that rectangle button to activate rite? Are there any more screens after that?
XiaoJinLing
If I am existing starhub user... port over to giga still need to wait for new sim card and pay delivery fee? Is it using the same starhub app?
