- May 3, 2001
https://www.facebook.com/gigaexperience/photos/a.2261050627315151/3389854187768117/
What is this 1GB whatsapp pack about???
Normally is 1gb for $1 for WhatsApp usage.
Now is 2gb for $1 promo.
ported to Giga on 11/9 ,
indoor signal very weak ,sometimes even with 4g logo but not able connect to network.
after one week testing , go back to Gomo yesterday ,
luckily still entitled the last day promo $20 for 40GB.
same here got the sim just now. Port to gomo. Data rollover because I can't use themi have the same experience with giga. sometimes cannot do safeentry check in because i suddenly lose connection. full signal bars and 4G+ logo, but no internet.
porting in to gomo (hopefully tonight). just received the sim this afternoon and waiting for the porting process.
Yes! It's frustrating and embarrassing, actually. I had the same experience with circles life, but to a lesser degree. I moved to Giga thinking it will be better since they use SH network. Hopefully I'll get a better experience with gomo.i feel you !! same situation with me before , end up need scan my NRIC.
is giga tied onto contract? other then that giga or gomo which is better?
So far I experienced at Ion, after alighting the mrt, and AMK Hub, going into Fairprice. Also experienced in Upper Thomson - Sin Ming area, and it is outdoors. The internet just suddenly disappeared. I had to reboot the phone to get back the connection. It never happens when I am at home, where I tried using data the whole day and night.Which area ? So far I haven't been to any place where it's totally unusable.
Sent from my phone using GAGT
Do you by any chance turn on your WiFi all the time & set it to switch automatically bw mobile & wifi?
I have this problem when my phone picks up wireless sgx wifi but the wifi signal too poor to get internet.
Sent from Gigafied Nordy Way using GAGT
No. I turn off my wifi when I go out, either with Bixby routine or manually. Even if it was the wifi connecting to wireless@sgx, then it should show the wifi icon. But no, it only shows the 4G/4G+ icon. And it also happened outdoors where I'm pretty sure there is no wireless@sgx.Do you by any chance turn on your WiFi all the time & set it to switch automatically bw mobile & wifi?
Anyway, by tomorrow I will be using gomo. If it still happens the next time I go out, then there must be something wrong with my phone. Lol. *********
Yup. Thanks. I also only saved the giga apn.Make sure you using the giga apn instead of shwap apn. Although the starhub apn works but sometimes it just stopped intermittent. Happen to me until I changed the apn to giga
