[Temperature] CPU & GPU idle & load running temp - Please share here!!
CeleronD
1st i5 3570k. no aircon. idle abt 35deg. prime 75 deg oc to 5ghz at 1.294v. phanteks tc-ph14pe
2nd i5 3570k. aircon rm. idle abt 28-30deg. prime 62 deg oc to 4.5ghz stock volts on kraken x40
2500k. no aircon. idle abt 38 deg. prime 70 deg. no oc. stock volts. stock cooler
i5 750. no aircon. idle 31 degs. prime 70 deg(oc 3.5 4 core, 4ghz 1 core). 1.296v. prima boss II cooler
dun check my gfx temps cos dun oc them. maybe i buy one off amazon and oc
luei74
Just setup my rig 2 weeks ago. Is the temp normal on stock hsf?
nikamura
mine :)
AnTiLooP
my rig on the right gets -----
26-30C idle
IBT High Stress - 74-76C
Prime Blended - 65 C
Aida64 - 65 C
room temperature around 24-26C.
i1magic
Dear all,
Please indicate your room temp when you post your results.
Thanks.
i1magic
This is mine.
Ambient / Room temp : 29 degC, non aircon.
My gfx card is EVGA GTX 680 4GB, that's why higher temperature.
Basically,
1. My CPU temp is about 6-7 degC above room temp
2. My GPU temp is about 13-14 degC above room temp
The rest of you having 760 and 770 all have temp about 35degC only? So low?
sHrike
Room temp is about 27-28 C
The min temps are the idle.
The max are from running the IBT
i1magic
What HSF are you using? GTX 7XX series gfx card is really running cooler than GTX 6XX series.
sHrike
This is mine.
Basically,
What abt ur temps when full load?
