[Temperature] CPU & GPU idle & load running temp - Please share here!!
i1magic
This is mine.
Ambient / Room temp : 29 degC, non aircon.
My gfx card is EVGA GTX 680 4GB, that's why higher temperature.
Basically,
1. My CPU temp is about 6-7 degC above room temp
2. My GPU temp is about 13-14 degC above room temp
The rest of you having 760 and 770 all have temp about 35degC only? So low?
What abt ur temps when full load?
For gfx, at full load should be 80degC IIRC. Is that reasonable?
Hua_Hui
how do u guys get so low temp? and some of ya even using stock hsf.
I'm like 46-49 degrees idle, 80 degrees loaded. zzz can help to remedy?
non-aircon ambient, using gentle typhoons (1 for input 1 for output) with bitfenix shinobi
I suspect my thermal paste not properly spreaded plus hsf not properly seated
screenshot added:
i1magic
screenshot added:
My cpu temp for this period is about 35-38 degC range.
If you suspect it's the thermal paste, when you "wash" your HSF next round, then you'll get a chance to reapply your thermal paste.
vitadrink
Guys, I was wondering are these temperature alright for idling?
Nowadays my PC keeps on crashing so I thought it might be a overheating issue even when idle.
sHrike
<70C are normal operating temp for cpu. Why would they crash?
If yours crash , it must be due to some other reasons.
i1magic
If PC crashes, if the RAM is not too difficult to take out, take out 1 by 1 and try.
If ok, reinstall OS and try. Usually the problem is NOT due to cpu.
soufigo
Mine at Load using AIDA64. no OC, stock clocks using corsair h80i in aircon room, ambient about 26'C. forget to add in Gpu in the HWmonitor. my GFX was also stressed at the same time. maxed out at 75-76'C after about 4mins. didn't go any higher for the next 5mins.
Specs on the right--->>
edit: I realised pic was small to see numbers. idle was between 26'C to 31'C, load was about 65'C at lowest core temp to 72'C at highest core temp
vitadrink
I don't my ram is the problem because I have tried that a lot of times. Maybe I will do a reformat and see how things go. Thanks for your input. :D
i1magic
So you mean at room temp is 26'C and your cpu is between 26'C-31'C? And when full load, cpu hit 65'C-72'C?
Correct?
How about your gpu?
soufigo
Correct?
How about your gpu?
That is correct
Already state gpu temps before pic. Anyway after 4mins of gpu stress test by Aida64 temps hit 75 to 76.then stay there for the next 5mins.
