[Temperature] CPU & GPU idle & load running temp - Please share here!!
i1magic
Seems like it depends on the mobo... looking through the threa, some ppl dun have, some ppl have.. for asrock, it is missing the +3.3v, +5v, +12v..
Different motherboard uses different chipset which will reflect different information.
MacClipper
A10-6800K@4.8GHz@1.425V, idle 30.5C, load 52.6C custom water
http://forums.hardwarezone.com.sg/79572891-post42.html
xvid4PSP_48GHz_1086MHz_DDR1866_OKCopy_zps0ecb6580.png~original
Quite power hor? =:p
kimsix
room temp is 30 degC
all intel power savings are enabled.
tamjinhang
As requested, some pics incoming...
- Here u see the 3-mode switch on the NZXT Phantom 630 (currently set at middle); down for lowest speed, up for max speed. There's also a light indicator to tell u what speed setting the switch is at now.
- Quick view of fans inside the workstation
- Internal fan hub PCB that comes with the case. It has 10 fan plugs! I managed to connect 11 fans by using a Y-cable to connect 2 fans into one fan plug. On a side note, anyone has a sleeved GT fan? I still have one odd one out left ><
xtreme84
Here's mine, stuffy night in SG, no aircon, rig been turned on for surfing for about 2 hours.
CPU overclocked to 4.5GHz, specs on right.
i1magic
If you watercool, your GPU temps probably around 38 and load around 42.
That's how bad GPU coolers are lol.
Yah. Apparently the MSI Hawk range has pretty good air cooling.
As for water cooling, I got a friend who did water cooling and then revert back to air cooling. He told me that water cooling needs alot of maintenance and regular checks for possible leakage.
Fatfool
Idle temperatures. Ambient is around 22 degrees right now. (not in Singapore)
I'm not sure what the processor temperature actually is though since there is one temperature listing for both processors. Hell, there should be a whole list of entries for each core.
Anyone want my load temps?
i1magic
Yours should be notebook?
Should be about 27degC.
EatSnakeWarrior
with:
I5 - 4670k
cm 212 hyper x = 35 deg idle // prime 95 (3.6 gz no OC) = 55 deg
stock cooler = 38-41 deg idle // prime 95 - did not test
sibotak2001
Entire 24 hr period lowest temperature for CPU die package of Core i5-4670k with CM212 cooler :
32 degree Celsius
Lowest for Powercolor 7850 PCS+ running two monitors only:
42 degree celsius
