[Temperature] CPU & GPU idle & load running temp - Please share here!!
JasK
just setup rig, after being on for a night, idle, room temperature
foo9883
Room temp: Whatever room temp SG has.
GPU Load(DmC Devil may Cry): 87C on both GPUs
CPU Load(DmC Devil may Cry): 55C
i7-2600 @ 4.0 Ghz 1.22v (CM Hyper 212+)
Dual 6970 reference @ 940/1450 1.23v
Cannot run Furmark on my rig coz will reach 98C I scared.
jarred1223
Typical room temp as well.
All those using Xeon, the temps like too low to be true sia..
junialum
Great thread. Most people check temps on review sites in US / UK / etc where their ambient room temps are way lower.
eminus
How come yours got show "CPUFanXX", "SYSFanXX", etc .. but mine don't show? Only got "FANIN0", "FANIN1", etc.
Room Temp : 27.5degC
[IG]http://i48.tinypic.com/90ak9t.jpg[/IMG]
no idea man. I got 6 HDD but it only show 3. Weird.
that is because Gigabyte,Asus, MSI and etc use different kinds of chip to monitor stuff in your motherboard like most:
MSI uses Fintek
Giga uses ITE
Asus uses Nuovoton
etc etc etc
JasK
Not really low, isn't it just a bit off? those on water cooling have nice temps, mine is only air cool
i1magic
Could you run HWInfo and post screen shot so that We can see more details?
i1magic
I am running Xeon. If I were to keep my browser opened, the cpu temp will goes up to about maybe 34—35degC liao.
So I closed everything and take the readings.
Did you closed all running programs?
i1magic
Yah man, I find that most reviews only state the temperature readings but very seldom they includes the ambient / room temp, which is a very important factor.
i1magic
My rig ...
Room temperature : 29degC, non aircon
But my GPU temperature seems high.
Previously when I was using the GTX460 ... the idle temperature is about 3-5degC higher than room temperature.
Anybody else having EVGA GTX680 4GB also can advice the idling temp?
Cpu : Intel Xeon E3-1245 v2
Gpu : Evga GTX680 4GB
Motherboard : Gigabyte Z77X-UD3H
For those who say some temperature of Intel Xeon E3-1245v2 is too incredibly low ....
This is the screenshot for this morning.
Room Temp : ~28degC
jarred1223
Room Temp : ~28degC
This looks more 'realistic' you know?
If ambient is 27deg and your cpu is only 1 deg above ambient temp, your cpu cooler is like ultimate kind :s22:
i1magic
Room Temp : ~28degC
Yah lah. The latest one I posted .... CPU temp went up .. but GPU temp came down as compared to my earlier ones.
So this is to show that the readings are just taken directly and post. As to why the difference .... really don't know liao.
