The Power Supply Chart
Ginster
Going to have my 1st rig, appreciate for any info.
Need some help on configuration and PSU recommendation.
Mainboard + core = Gigabyte EP45-(ds3/ds3r) w/ intel c2d e8400 $450-480
or Asus P5Q pro p45 w/ intel c2d e8400 $475
Graphic = Palit Radeon HD4850 512mb ddr3 (sonic) $269
or Sapphire Radeon HD4850 512mb ddr3 Toxic Zalman Fan $289
Memory = Kingston ddr2 6400/800 cl5 (2gb x 2) $106
Hard drive = Western Digital 250gb $76
Opptical drive = Samsung s223 22x dvd+rw sata $39
PSU = (Please recommend)
Casing = (please recommend)
Thinking of PSU CM realpower m520 or corsair hx520w ( is it sufficient for my built)?
Casing Liang-Li PC7FW. (Don't need blink blink).
Please correct me if the prices is wrong at this POT.
Thank in advanced guys.
Ray1026
For PSU if ur budget is enough. I suggest you choose CM New Selent pro 500W($159)...I bought 700W is $239...It is Modular and high efficiency85%...And 5 years warranty...
Ginster
Thank you for the info guys, i prefering the enermax modu82+.
towjj0202
help me plss
Hi there,
i am currently using having problems with running crysis using 4850.
Its quite laggy
Friends have suggested its the problem with the PSU.
Current specs:
3dmark06 score: 7800 plus( is this normal?)
MB: Palit N73PV
GFX: Powercolour 4850 PCS
2GB DDR2 RAM
Intel Core 2 duo e 7200 ( no OC)
Current PSU: Andyson 450W
Is my PSU the source of my problems. or is it anything else?
beano
I don't see Antec on the shelves anymore, which is the next best thing(PSU) on par with Antec?
inxlee
my antec truepower broke down. haha replaced with acbel 470w due to 5 years warrenty:D
towjj0202
Noob question
Hi all,
Just to check,
If lets say i am using an andyson 450 w
based on this chart i have dual 12v rails.
My total effective wattage for my 12v rails is 360W.
That means 180 w per rail right?
so my amperage is 180/12= 15 A per rail?
Is that correct.
Anyway if i am using a ATI 4850 running on an intel core 2 duo 7200,
is that enough?
imanon
Hi all,
Just to check,
Is that correct.
is that enough?
refer to chart:
http://www.andysonet.com/pdf/A Serial.pdf
try the psu calculator:
http://www.thermaltake.outervision.com/
450w may be a bit low, 500w safer.
certified psu:
http://ati.amd.com/products/certified/powersupplies.html
Mystyque
Hi all,
Just to check,
Is that correct.
No, it doesn't work that way. The Andyson 450W is rated for 18A/16A, but the local version is somehow 20A/20A. This means locally the Andyson 450 can provide 20A/240W of +12V power on either rail, with the other rail then limited to whatever remaining capacity there is, up to the max the PSU can support.
is that enough?
Yes, and again unless you're clocking the hell out of your CPU and graphic card :D
