Thinning Hair problem
Constantine
any good shampoo to recommend for cleaning oily/greasy scalp?
Is nioxin shampoo gd?
where can i get it in singapore?
I cant find it at pharmacy or watson.
Constantine
My top frontal is thinning a lot and crown also started to thin down...
Now i am thinking of whether going for hair transplant or trying out the Topical application like Regaine minoxidil...
Does topical minoxidil has any side effects? Will it cause hairloss more during the beginning stage of using?
Is hair transplant a more faster and more effective solution? Any side effects or risk?
Any views to share?
Thks!
PostCountWarrior[+1]
Any views to share?
Thks!
take propecia +minoxidil first... see how much hair u can recover back first b4 hair transplant...
pcw +1
Constantine
Hi Postcountwarrior,
So how long u been taking propecia + minoxidil?
I worried that it can onli stop my hairloss and maynot promote hairgrowth..and it will take a long time rite?
Hair transplant seems to be a faster way...
Btw, hwo long u been taking propecia+minoxidil?
Dis u encountered bad shedding during initial stage like some ppl encountered?
toblerone
Propecia doesn't help my hair regrow, it did slow down the loss initially but now hair has started to thin rapidly. I think my body is getting resistant to the propecia.
Very sad......no other option liao but to accept balding......
Constantine
pcw +1
So you do see stoppage of hairloss plus bonus hair growth after taking propecia+minoxidil?
How long u take to see positive results?
Why you do not recommend hair transplant in your view?
Constantine
Hi toblerone,
How long u been taking propecia? How long u take to see stoppage of hairloss?
Why u dont consider hair transplant?
Constantine
Recommended dosage for propecia is 1mg?
And which brand of topical minoxidil is recommended? 2% or 5%?
Any advice? Thks!
Benihime
May i know how much does propecia and proscar cost? Do i need presciption to get them ?
animeonegai
my hair follicles is growing very near to the surface.. the thinning is getting worst. Any professional help I can get?
toblerone
Hi toblerone,
Took propecia for abt 1.5 years. Hair loss reduced abt 6 to 7 months after. Cost of hair transplant and fear of shock loss..........
unwanted
You want sound advice?
Firstly propecia can really turn you impotent PERMANENTLY.
It can reduce and maybe regrow a little hair.
Dun expect much effect.
There are alot of cases of the drug suddenly lost effect and what ever you grew suddenly withered and dropped off.
It's not about the money, it's the impotency which is a big issue.
IMO it's not worth it.
Secondly, for people who are losing hair on the crown.
Can use Rogaine.
It works only on the top crown but not on the residing hairline.
At the moment, i can't find any solution to residing hairline rather than hair transplant.
I've a friend who did this and it works the best.
He has successfully got back his Aaron Kwok look.
1) Hair transplant from back to frontal. (From Thailand; They are the pros and they are 1/4 price of SG)
2) Use Rogaine on the top.
MOST IMPORTANTLY, maintain it. With right shampoo and maybe rogaine.
Whether you maintain it now before it has effect, or whether you already did something which works and you should protect it.
If you have a son, i will advise you to advise him to use the right shampoo with immediate effect to avoid future woes like you who is reading this now.
There's two shampoo that are highly recommended to be effective which i don't know why it's seldomly mentioned. Anyway find a good shampoo and use Rogaine.
Constantine
Can use Rogaine.
So which are the two good shampoo that you mentioned?
And heard that rogaine will cause initial shedding rite?
How long u taking rogaine to see its effectiveness?
