TP-Link is improving the EasyMesh technology with more recent firmware updates. So hopefully it will get more and more mature.
Dongknows review of TP-Link EasyMesh in June 2025 for reference.
https://dongknows.com/tp-link-easymesh-wi-fi-system-review/
Conclusion
TP-Link EasyMesh can be a handy option if you want to quickly extend your router’s coverage just a bit more.
This situation applies when you have a single Archer router that can nearly cover the entire home. Now, get an EasyMesh extender, and it’ll finish the job. If you need more than one extender, chances are things will get significantly worse and less reliable.
So, if you can buy a couple of Archer routers at a low price and have a wired home, a big if, EasyMesh can be a worthwhile option for building a Wi-Fi system from scratch.
Still, in most cases, you’d be better off going with more established DIY options, such as Ubiquiti’s
UniFi or ASUS’s
AiMesh. Or stay with TP-Link’s
Deco family.
Pros
Lots of hardware options
Relatively easy to set up and use
Flexible wireless and wired backhaul (with applicable hardware)
Responsive web interface with optional Tether mobile app
Cons
Minimum control of the satellite via the interface of the primary router.
Wireless backhaul can be complicated with no MLO in any Wi-Fi 7 combo; virtual SSDs (Guest Wi-Fi, IoT, etc.) remain at the primary router only.
Seamless hand-off reliability could be better.
