TPG Technical Discussion Thread
mankind66
Thanks for the advice. What do you mean reset tpg line? I told my friend to reboot phone but that didn't work for him...
Sent from Xiaomi POCOPHONE F1 using GAGT
I switched off the tpg line in network.
Tap on tpg
Tap to turn off tpg
Now tpg is off
After that, turn it on again, it should reset.
whoooo
Guys, check with you all. My friend is using xiaomi phone, and I managed to help him do the settings for the simcard to work liao, both data and calls. When he went JB yesterday, he says can't detect network so didn't get to use the auto roaming data. And after he came back Singapore, he can't use the data and calls here liao. I haven't got the chance to see his phone yet, but I hope if anyone can give some advice so I can help a friend too.
Thanks. :)
Go setting - more - reset WiFi, mobile data, Bluetooth -> reset the mobile data and the TPG
kcyang91
SIM CARD NOT WORKING
i went to Indonesia and i activated the roaming.
the line is not that stable and sometime the internet is suddenly not working and have to wait few minutes and the internet came back,
then i across this issue. suddenly came out with SOS call and suddenly the whole sim card unable to detect in phone. tried with another sim card for the slot used or swap either way. im sure its the simcard issue.
it shows NO SIM CARD at the slot.
Charlie_Zhan
Just got my own TPG SIM to use in my E5885 mobile router and the speeds are so unbearably slow even for normal web browsing. Instagram and Youtube is pretty much unusable.
Tried it on my phone and the speeds are fine. So why are they throttling the speeds on my mobile router?
I'm getting speeds below 0.5 megabits per second which is ridiculous.
firstly, how is this considered "ridiculous" why you are not charged to use their services.
secondly, this phenomenon should not be coming to as a surprise since it was already mentioned under the trial's FUP section.
Yah they are throttling all mobile router. so to get good speed is to share via phone. Not sure why, email them before they just don't wanna address this issue but suggest you to use Phone instead of router.
because they most probably overestimated your ability to read the FUP and thought it wouldn't be nice of them to reply you with the link or screenshot to it and make you feel like they are trying to challenge your capability to do so.
Sausage
I cannot get any reception around 2nd link both spore and Malaysia sides
Sent from Xiaomi REDMI 7 using GAGT
Alphas
I have Redmi note 7 and it cannot get any mobile data. There is TPG 4G mobile network connection and the signal bar is full. I tried to do a reset of mobile network but still no internet connection. Does anyone knows how to fix this?
squarepipe
Add the APN settings to your phone. I am quite sure tpg gave you instructions specifically for that.
lenseview
Tpg apn is tpg. Just create a new apn. Under apn slot just put tpg. Others dont bother. Save and activate. If you set apn before, sure will know.
Dont see the need for any instruction.
Ian
Try disabling VoLTE carrier check.
*#*#86583#*#* and you should receive a message "VoLTE carrier check was disable"
magix
No. TPG change their FUP after everyone go buy mifi to use TPG. My FUP says different. *Yes they have to right to add anything in their FUP*.
But well is free they can do whatever they like. With the current FUP and no coverage in mrt. Pretty useless for me also. I spend 50% of my time on phone while on MRT.
TPG was the best for Mifi because
1. VoLTE device limited (until today apple still refuse to enable VoLTE on Iphone)
2. None of my 4G phone android support VoLTE.
Pohhenry
tpg in lte router
me too
put tpg sim into archer mr600 speed like snail
but strange thing is speedtest show high speed
youtube cant even play song
so tpg is only for phone and tablet
mifi and lte router cant support I guess:s22:
sadboy
me too
Yes they jam the speed and only allow Speedtest to run at full speed making u feel that your mifi spoil.
Pohhenry
is there any way to overcome this jam?
read in the net that VPN can bypass this capped speed
but don't know if it is true or not
their sim card seems like can recognise device one
see the speedtest so happy
but when I use hotspot teter speed good
lte 4g router don't work...sad
kenvin05
anyone experience before if I lost my TPG sim card, can i just go to the sim card pick up location to direct get a new sim card ? or it is better to get another new number XP?
