TPG Technical Discussion Thread
Elon Jobs
squarepipe
Lol so long liao still haven't fix voice calls for iPhone. How to open business next year when so many iPhone users in sg :yawn:
More like apple fault for not supporting tpg VoLTE.
Worst case tpg need to release an app specifically for voice calls like what reliance jio does.
squarepipe
Every single phone model must be “certified” by TPG isizt? Lol
If your phone support LTE bands 8 and 40 data and SMS will work. For calls to work your phone must support TPG VoLTE standard not the other way round. Other telcos can make calls even without VoLTE as they can use their 3G networks for calls.
Habrosus
I cannot get any reception around 2nd link both spore and Malaysia sides
Sent from Xiaomi REDMI 7 using GAGT
After using my line in JB the other day, I was at Tuas CIQ waiting for the bus and got both TPG and Yes4G when I wanted to change back to local network.
tohwk
Hi all. It's my first time using this TPG SIM card.
Must i enable data roaming if i want to use it in Malaysia and Indonesia? Thanks in advance.
Habrosus
You have to enable data roaming only if you want to use data from your TPG SIM card while in Malaysia and Indonesia.
Without enabling data roaming, you can still use your TPG SIM card for other purposes, like text and calls, if supported.
Pohhenry
TPG sim card seems to recognise device when using
Was told by cso that all mifi are not supported
Only smartphone and tablet
tohwk
Thanks for this info!
efreelancer
Recently I tried to hotspot to PC using redmi 4x. It got super throttled or even no internet. Earlier no issues with hotspot. How to overcome this? What app is good to mirror phone screen to PC. Too bad Mi suit does not work anymore.
hotsnowi
have you checked if it is under the list of supported devices on TPG website?
No it's not.....same brand but different model. Have band 8 and 40 too.
really must from the list from TPG?
Any other way to use other mobile models ?
Charlie_Zhan
means you already have the answer to your initial question..
Mecisteus
Yes only certain phones can support.
My daughter's Oppo R9 plus is not supported.
Cannot expect much. It is free anyway. =:p
