TPG Technical Discussion Thread
cruizer_ph
i don't think anybody can use TPG right now in "mission-critical" fashion. if you happen to be in a place where there is no TPG (4G) signal, good luck...
lohsenglte
If you're using mobile data for mission critical purposes... Good luck. Latency so high compared to fixed broadband, there's a reason why 5GNR SA and it's <1ms latency is required.
limpingsim98
This also means you only use TPG for non critical mission. I am sure if they are going to charge you the same as other Telco, you probably will switch to another Telco.
Thats right. You don't use a Telco which operation is unpredictable. Play line is ok.
limpingsim98
You are right. Too much variable from TPG. Not even sure they already fix issue with TPG call to land line. Is like sometime works and most time failed.
kurt111494
Sorry can I just check...when I first signed up for their free trial, it was mentioned that it would be free for 1 year. Now my 1 year is up...will they auto cancel this 1 year free trial of mine? Or will it continue on and start to auto charge me?
keenklee
CPTMiller
They cannot just auto charge a trial user to a paid user.
They need you to acknowledge it first.
tuntun
Why TPG settings are still not supported imn IOS? Most apple IP6 users got issue with APN setting. Even though set as manually, it intermittently prompts as update tleco profile but nothing and line was unable to use till reboot.
s3856
My IP6SE is unable to call another telco. But when I installed Singtel,SH or M1 SIM card and no problem to call or receive call. Not sure other IP than IP6SE got the sam problem? Or the problem only issued to all IP. My Samsung phone no problem to cal and receive call for TPG SIM card.
hereiam7788
What is iphone 6SE? Got such a phone meh?
hereiam7788
My iPhone 6 (iOS 10) has no issue. Can use TPG data and can do personal hotspot even. Speed is good.
Can use 10GB+ incl. the 2GB uncapped speed data.
s3856
Can call and receive call from other telco fixed line( Not whatsApp data call)?
lohsenglte
TPG VoLTE only supported on iOS 13 and above for iPhone 7 and later users on INTEL modem.
Qualcomm modem iPhones aren’t supported.
Just install the TPG voice app to make calls instead.
s3856
Will reconsider to get TPG since unable to support IOS phone.
*adiBOY
You means iPhone? I think iPhone use Intel modem. Not sure on SE model.
iPhone SE still uses Intel modem. Only this year iPhone 12s will all move to Qualcomm modems before Apple uses their own chipsets in 2021.
Apex
I think need new iOS version and enable the Voice & Data
- Proceed to Settings > Mobile Data > Mobile Data Options > Voice & Data.
- Select LTE, VoLTE On. Or, 4G, VoLTE.
Iphone 7 onwards than support TPG.
