TPG Technical Discussion Thread
eip1234
Hi Bros, this might have been discussed before but couldn't find it ...
For the $10/50Gb plan, is there any daily cap for the full 4G speed before throttle speed kicks in?
I understand that it's 2Gb per day for the free trial sim.
Thanks thanks ...
hereiam7788
Thanks thanks ...
Dun have. Just that after 50GB no more unlimited data at throttled speed like the trial.
hereiam7788
I think need new iOS version and enable the Voice & Data
- Proceed to Settings > Mobile Data > Mobile Data Options > Voice & Data.
- Select LTE, VoLTE On. Or, 4G, VoLTE.
Iphone 7 onwards than support TPG.
Not really my iPhone 6 Plus on iOS 10 also can use TPG data with no issue.
haoKRR
I received a mail from tpg saying my free plan will expire at the end of this month. Either I cancel it or migrate to 50GB sim plan
Sent from Google PIXEL 2 XL using GAGT
hereiam7788
Same. All should have received it.
magix
Yah they resent (2nd version has a correct end date/month).
mankind66
What to do if i don't want to continue?
carboy00
What if we forget our password and unable to login into our account?
Reset password works now, so can reset it and login to terminate, if not drop them an email and they will send you a link to reset it.
Posted from PCWX using Redmi Note 8 Pro Ocean Blue
Sofa_King
I got 2 numbers but email show only 1.
login account also show only 1.
How to terminate the other number?
Really rubbish system, forget password doesn't work at all. Even the MVNOs have better UX than TPG.
I'm just going to let it lapse and expire.
