TPG Technical Discussion Thread
icyflame
Essentially they are charging $10 for 10gb less than the trial (2gb x 30).
Will be terminating once trial is over as this is not suitable as a main line for now.
kokfann
So many cheapskates here. Already using the free service for so Long and now still gonna complain. They won’t Suffer loss without your subscription, but I foresee you, sooner or later will crawl back and get TPG as it offer best bang for bucks and still will continue to kpkb here. Lol...
icyflame
Will consider den in 2 years time once they sort it their underground coverage
Precisely. I applied to test the system. Used for less than 10 days over so many months. While the speed is good when it works, there are too many blind spots for now. Will not rule it out when it has better coverage in future but definitely not suitable for now as main line.
Shion
Senior Mentor
I am happy with TPG even though the signal in underground/basement and MRT tunnel is close to (or simply) zero. Can simply switch to my Singtel line before switching back to TPG line when I reach the ground.
limpingsim98
Stinktell response...
TPG is really a company lack of management skill!
limpingsim98
Well is free. Once they start charging, let us know if you still happy with their coverage.
hkchew03
Only good enough as a 2nd line, as free or super attractive price, anything else its just not worth it until they get the coverage up on par with competitors.
Imaging using TPG as your main without your current line.:s22:
cscs3
Technically is not a free service by trail service. They are using you to test their network without paying you!
cruizer_ph
as long as TPG can have coverage in the underground MRT stations by the time they roll out their commercial service (not trial), then it should be OK...
Shion
Senior Mentor
Sure, why not ?
Yes, I use it as a 2nd line :s12:
cscs3
Sure, why not ?
This also means you only use TPG for non critical mission. I am sure if they are going to charge you the same as other Telco, you probably will switch to another Telco.
cscs3
Wow. Seems like you are the victim here. Go sue them for not paying you.
Believe iMDA is going to issue a fine to them soon.
If you check their Facebook, so many issues including those people trying to port number between them!
Comment from other 3 other telco, they are not the full service telco yet!
mobster
Is the roaming in Malaysia still on or cancel already? Was in batam during Cny and it was still working
