TV tuner recommendation
LxIxVxE
Senior Mentor
Hi guys. Seems like most of you are reviewing AverTV Hybrid Volar HX. How about AverTV Hybrid Super 007
PCI?
Am i right to say, for hybrid tv tuner you can receive Channel U using analog????
Last thing, anyone using averTV hybrid volar HX and stay in choa chu kang?? Are you able to receive most of the channels? I'm living on the 4th storey only :(
Thanks!!
AverTV Hybrid Super 007 is not bad~ :)
for $70+ only is worth it~ :)
if dun mind second hand one, can consider the hauppauge wintv hvr1300 in the garage sales~
if can get below $80, not bad~ :)
yeah, hybrid can watch ch U~
Blue.Wing
Thanks LIVE :s13:
any1 living in cck ??? just wanna check how's the reception over here :D
Bonn
the avermedia duo hybrid pci-e II is available now. i think some ppl were looking for it ba
Is it available in Singapore? I see most shops still carry the old version. i.e without the II behind.
sHiErShAo
Hi all,
Need recommendation for tv tuner. I would like to get usb tv tuner so which brand and model is recommended? Thanks all.
ordico
yeah..
i only found out after the show... so sian.. i called 1 day after n they quote me the normal price. :(
Hope the offer comes back for this show. I'm also buying a RMVB/DIVX player...
mike911
my mind is made up with the hybrid avertv one.
now is whether to buy or not... suddenly my shopping list becomes crazy..
cybertech
Is it possible to watch 2 different channels same time since the
Avermedia duo hybrid pci-e got two tuners ?
mike911
from my knowledge u need seperate tuners to watch different channels @ the same time
cybertech
that card got dual hybrid tuners~
means u got 2 hybrid tuners~
meaning can watch two different channels at the same time right ?
my guess cannot use the same TV app as same app won't launch
the 2nd time when it running, probably got to use another TV app
to show TV Tuner #2 :s11:
LxIxVxE
Senior Mentor
the avertv software can do it~ :)
cybertech
I know of the AverTV software can do the PIP, I am actually looking at
running two separate TV app e.g to watch CH8 CHU on screen (resize windows):D
Can ? :)
mike911
Can ? :)
erm, u noe about modding the manila2d? got time i pm u about it. wanna learn about it, u noe about the wm6.5 too?
LxIxVxE
Senior Mentor
Ok thanks. So can be done :D But first thing I got to get the 2nd tuner Digital Signal
to work first, my house the old TV port (Roof Top Antenna) couldn't receive digital signal:(
but for wat~?
watch one and record one in backgrd better lor~
impossible to concentrate on 2 show one~
cybertech
but for wat~?
All along I watching TV and surfing same time on same screen also mah.
So if enable one more TV screen can watch what is going on other channel :D
