TV tuner recommendation
LxIxVxE
Senior Mentor
only bizgram have this product rite?
what is the main advantage this product compare others? usb+harware encoder?
think can get from AJVW distro directly oso~ :)
only advantage is the hardware mpeg2 encoder for recording analog channels~
disadvantage might be the requirement of wall power socket, cannot use anywhere u like~
reflush
hi,
any recommend for very strong reciever tv tuner?
the place is not near window(at least 20 meter in any direction to the nearest window), also don't have wall socket for antena.
if still want try, which model/ brand you all can recommend
thanks for any info
neohkl
Any recommendation for a USB tuner for Asus 1000HE. Windows XP. That is also good for Malaysian channels when in Malaysia. Thks. Budget $50 - $150.
TIA
darkarn
Just wondering, are all TV tuners with recording features using MPEG-2 hardware encoders? Or is there any model using other (or even higher quality) encoder?
LxIxVxE
Senior Mentor
not all got hardware mpeg2 encoder~
most tv tuners still using software encoder~
got hardware mpeg4 encoder but the tuners not available here~ :(
darkarn
Man... I guess if they are in Singapore their prices will be insanely high, right?
darkarn
I think Snazio also got such encoders, but I cannot deterine whether they are using software encoders...
LxIxVxE
Senior Mentor
cybermind got $19 usb dvb-t tuner~ :)
LxIxVxE
Senior Mentor
which shop in SLS is selling avermedia pci-e tv tuner card ??
AVerTV Duo Hybrid PCI-E II or AVerTV Ultra PCI-E RDS~?
first model quite common~
remember to get the II version~
fuwell, videopro, etc~
AVerTV Ultra PCI-E RDS can try videopro~
if dun wanna go SLS, can get from potterhouse~
daylight
Why II version is better ??
tatsit
High Honorary Member
ish recording/viewing hd5 laggy or cpu intensive for those using tv card without hardware encode?
chanlwoo
After watched game on TV
Today I find a new website. Though its design is not fashion, its goods are cheap, such as nfl jerseys, mlb jerseys... Meanwhile, its service is good. I like such it.
