TV tuner recommendation
shokbakgoc
not much choices avaliable locally~
avertv is ok and quite cheap~ :)
if u using lappy, or need to bring it ard, switch between pc, then get usb one lor~
if using desktop with spare pci slot or pci-e, then get internal one lor~
usually cheaper for same functions~
the extra money can be used to get cable or a powered antenna~ :)
can recommend which powered antenna? where to buy? those rabbit ears antenna from sls don't seem good?
LxIxVxE
Senior Mentor
no recommendation as there is no guarantee what you will receive even with the recommended antenna~
some ppl can receive everything with juz the default antenna(comes with usb tuners) or those $3 $4 non-powered rabbit ears antenna~
while some ppl not able to receive anything even with a powered antenna~
maybe u wanna go SLT and take a look~
kim teck #01-09 sells quite many kinds of tv antenna~
kaichin on 3rd floor has some too~
shokbakgoc
thank you very much :D
reflush
Hi..,
anyone use usb avertv hybird volar hx with ubuntu/ other distro?
anyone can recommend tv tuner that work with ubuntu/ other linux distro?
thanks for any info
noidea
si there any third party s/w that can be use to watch TV channels ... ?
Im using pinnacle USB connector ... thanks
shenwu
i got a question
Are those digital tv tuner plug and play? Meaning just plug into usb port and can start searching for tv channels. Don't need to connect any cables from the tv point right?
LxIxVxE
Senior Mentor
i got a question
usually dvb-t usb tuner got include a mini antenna for receiving channels~
Sauzan
One more question.
Can the remote that comes with the avertv hybrid 007 pci card turn off the pc?
darkortal
any recommendation for digital and analog tv tuner for 50 dollars budget :)
if too lil then stretch to 100
LxIxVxE
Senior Mentor
usb~?
pci~? :s11:
pci got the avertv super 007 Hybrid @ abt $70+/-
usb got the avertv volar HX or HD @ $90+
des_kong
Buy This Guys !! Very good video quality and cheap . Im staying at amk ave 5 #11 floor . I Can receive super clear HD5 , Digital 8 , CNN , TV mobile and all other cannot be view SCV channels . No FM though . Ya need to find ya " best spot " out at the window for the antenna , wrong placement will result in poor reception or TV mobile nia .
http://www.dealextreme.com/details.dx/sku.8309
Used a 5m USB extension cable to hook up with this tuner so it can stretch its antenna out to my window . Anything above 10ft will need a USB booster type extension cable . Bought my extension cable for $7 at mustafa .
Hi where in SLS got sell this product? How much? Does this support Vista? Thanks!
tatsit
High Honorary Member
AverMedia AVerTV Ultra PCI-E RDS Hardware Mpeg-2 Encoding <-- is this one good? so far its one of the cheapest PCI-E hybrid with hardware mpeg2 encoder
