TV tuner recommendation
boontiong
my avermedia volar Hx just spoilt after a yr.
sad.
The back where i plug in the analoge cable came out. haiz, the cable think too heavy le thus the slot came out.
Time for a new tv tuner.
LxIxVxE
Senior Mentor
anqiang
Buy This Guys !! Very good video quality and cheap . Im staying at amk ave 5 #11 floor . I Can receive super clear HD5 , Digital 8 , CNN , TV mobile and all other cannot be view SCV channels . No FM though . Ya need to find ya " best spot " out at the window for the antenna , wrong placement will result in poor reception or TV mobile nia .
http://www.dealextreme.com/details.dx/sku.8309
Used a 5m USB extension cable to hook up with this tuner so it can stretch its antenna out to my window . Anything above 10ft will need a USB booster type extension cable . Bought my extension cable for $7 at mustafa .
Fusionzone
bro i am using the same reciever that you mention, any idea why i only manage to receive tv mobile ?
Staying at yishun area.
Regards
Andy
shapolang
Just wanna say THANK YOU VERY MUCH to thread starter and especially to LxIxVxE for showing the hybrid volar hx pic at #405.
Was thinking of getting avertv pci hybrid 007 until i saw the pic. Did some intensive research and finally decided to buy the usb hybrid volar hx (christmas edition).
Bought it at $93 cash (as stated in the pricelist) at Bell Systems at #05-68 SLS. Most other shops at SLS selling at $98 and some even at original $125. :) Didnt wanna wait for SITEX cause need to record some shows urgently.
Have not fully explored the capabilities of the stick yet. But manage to tune in to all digital channels including HD5 using default antenna at Toa Payoh area at 12th storey. Antenna is positioned at about 2.5m away from nearest window.
So overall, very happy with this product so far. :)
Following pic captured using latest avertv 6 reduced to 50% of original size.
des_kong
Does it support VISTA?
LxIxVxE
Senior Mentor
oic~
so it is a price cut rather than a promotion~ :)
wonder how much will they sell this time at sitex~ :)
nightmarepolice
Hi guys, what about the PowerColor Theater 650 Pro? A Tv tuner powered by the ATi theater 650 chip. Is it good for viewing digital and analogue channels?
Sauzan
so avertv hybrid usb one still the best?
will usb have problems compared to pci/pcie?
LxIxVxE
Senior Mentor
hihi
me new in this...understand that this is plug and play so can use in lappy n netbooks rt ?
Wat software can I use to record the tv programs ?
I can also receive all payable channel like JET huh ?
Thanks for sharing !:o
plug and play~
juz use the bundled software for veiwing or recording~ :)
no~
cannot watch paid tv for free~
unless u have subscribed, then u can connect ur box to the tv tuner and watch on pc~
LxIxVxE
Senior Mentor
not much choices avaliable locally~
avertv is ok and quite cheap~ :)
if u using lappy, or need to bring it ard, switch between pc, then get usb one lor~
if using desktop with spare pci slot or pci-e, then get internal one lor~
usually cheaper for same functions~
the extra money can be used to get cable or a powered antenna~ :)
Sauzan
Ok thanks, was worried that USB tv tuner may spoil more easily or may have stuttering when recording or viewing, etc heh.
Should just get a PCI one..
LxIxVxE
Senior Mentor
sometimes will see ppl complaining that their usb tuners get too hot and it becomes unstable~
cheap pci can consider the Avertv Super 007 Hybrid @ $75~
