TV tuner recommendation
Hafi
Any one have any idea where got sell AverMedia Hybrid Volar HX or HD?
Ask most of the shop today in SLS, but all no stock or selling other balnds like
Kworld. Please let me know if you happen to know which shop is selling.
Thank you.
i think no more liao, replaced by Volar HD at the same price and more functions + remote.
edit: oh I get you, sorry maybe no stocks wait for it to come lor.
shawn_sboi
Need recommendation for tv tuner for mac :) anyone?
is the elgato hybrid tv tuner good?
can it record or watch starhub channels?
shawn_sboi
Anyone can recommend me a DVR that i can record and transfer to computer?
if not a TV tuner?
i'm looking at EyeTV Hybrid - TV Tuner Stick for HDTV & Analog TV
for mac
tatsit
High Honorary Member
how is AverMedia AverTV Duo Hybrid PCI-E?
actually, is there a tv tuner that is compatible with 3rd party softwares? i want to use media player classic HC
scruffyhippy
Anyone using AverMedia Hybrid Volar HX or HD ?
When recording from an analog source (channel 8 or vcr) does the recording lag ?
Would U recommend this product to watch&record HD5 ?
Thanks
clock_ED
Hi,
I already have a TV in my room, however, I would like to output the TV to my PC concurrently, So does a TV Tuner allow it?
Or do I have to get an adaptor which will output to 2 Inputs?
TIA ;)
J_Man
Hi folks,
can anyone give me feedback on this Analog TV Tuner?
Hauppauge Computer Works : WinTV-USB2-FM
Hauppauge WinTV-USB2-FM. I saw it going for about $63 at a shop.
I have a Win 7 (64 bit system). Since I don't have a cable tv connection in my room, I'm just satisfied with the free-to-air channels such as CNA, Ch5, Okto, etc.
I basically just want clear pictures & the ability to record programs. Thanks for any input.
qscasdzse
Just to check around where actually sells Avertv hybrid volar HX/HD its seems like challenger doesn't have stock or am i wrong?
Apex
Avertv nor longer available in sg?
Can't seems to see them in fuwell (use to sell a wide range) and challenger funan.
Kiwi8
Deluxe Member
What model are u looking at?
Anyway, Singapore is in the process of converting to DVB-T2, u still want to buy the older cards meh?
cybertech
Agreed. I started looking around for a DVB-T2 dual tuner PCIe card already :D
coyote
Same here, looking for dvb-t2 usb dongle.
Using a dvb-t dongle for HD5 using mythtv. Reception is weak due to the only transmission tower at bk batok. They also stopped broadcasting the epg since 2013... :(
harky
i bought Hybrid Volar HD long ago but did not use much.. becos no cable
may i know which is the best cable i can get so i can connect a very long cable from tv Antennas there to my desktop? think at least 2m needed.
But than how to get HD if my SCV is normal digital rather than hD?
btw sg already on digital.. can record into ts or tp format a not :p
