Using E-gate MegaThread
Habrosus
Those who normally head for manual counters might as well take this opportunity to register for MACS2.0 and start using the eGates.
~sabaisabai~
Looks like it, since they said all foreigners. So those driving in will need to file MDAC too, including the occupants.
No, using the eGate will enable you to save more passport pages too
wah. my pages always under utilise. :s13:
going by egate must faster to clear jam hor
vsvs24
Going by normal manual counter. After filling up, need to print copy of submission to show at the counter ?
~sabaisabai~
do we need to download the apps? if yes. what apps? thanks much
Habrosus
I remember I'd one passport not nearing 4 years with all those stamps! :s13:
Yes, much faster via eGates. Just got to concentrate and make sure you place your passport properly, don't remove until the gate opens. Check the screen for any instructions while waiting, coz yesterday a friend got "remove passport and try again" instead of the old "please go to manual counter", so he could try again instead of wasting time running around.
Going by coach no chance to go to the special counter to register first time because the counter don't open so early.
I'd get the registration done a few days before the coach ride, don't risk being late even if the registration counter opens and there's a queue, etc.
Don't need to. But to play safe, I'd make a screenshot and keep in my phone just in case.
No app, just the webby: https://imigresen-online.imi.gov.my/mdac/main?registerMain
hwsstx
What is this MDAC?
MDAC is a scheme under the new MACs 2.0 system that is implemented by the Malaysia government to allow Singaporeans to use the e-gates normally only used by Malaysians
How to Register
Go here: https://imigresen-online.imi.gov.my/mdac/main?registerMain
Fill up the form, up to 3 days before you intend to enter Malaysia; with your details and you are set to go
The first time you do this, you NEED to go to the specialized counter between 8am to 7pm, Mondays to Thursdays (assume this excludes public holidays)
Link to a picture of counter
Once You Are Registered
Whenever you want to go, fill up the exact same form, the exact same way, but now you (should be able to) go through the e-gates, for both going in and coming back
FAQ
What for?
Do you like to go to JB via bus but don't like queuing inside CIQ? Then this is for you
If I'm registered, can I still enter/exit JB via getting a stamp at the counter?
Yes, you don't need to use the scheme if you don't want/need to
Can I enter using egate and exit via counter with chop and vice versa?
Unless something desperate happens and you are forced to approach the customs officers for help
Best practice is for you to go in and go out by the same method
Better safe than sorry, it doesn't matter that your friends or even the customs officers tell you; one chop without its corresponding twin is always a risk some customs officer can ki siao and get you into necessary trouble
Will this help me if I like to take coach or enter by 2nd link?
Depends
  • If you are taking coach as part of a tour group, the coach still has to wait for everyone, so while you can clear immigration faster you still need to wait, sometimes in the hot carpark/coach waiting area instead of the aircon immigration area
  • if you are taking CW bus; it can help because you clear immigration faster so you can be at the head of the queue
Can I register at the manual counter inside the train checkpoints if I'm taking train?
No
What if I drive/take car?
There's no egate when you drive in
Enrolled previously: Every time go need to fill up the form ah?
Yes
Enrolled previously: Must fill in in advance? If yes how far in advance?
As early as up to 2 days before the date you intend to enter OR you can submit the form when you are sitting in the bus bay at Woodlands waiting for bus to JB and it will still work
My father's, neighbor's, son's, friend say once enrolled, no need fill in for subsequent trip, why u ask me every time must fill?
In the early days of the scheme, some people can get through without filling in the form for their subsequent trips, now cannot already
Enrolled previously: I tried the e-gate but it give "Passport Read Error" how?
Try again but this time firmly press your passport down flat on the glass panel
If still cannot, try another machine
Still cannot, try another machine, until you try at least 5 machines in different areas of the hall (left side and right side)
No joke, sometimes Malaysia own passport also have same error, they just try other machine till can
If you are going into JB, first try the machines on the extreme left side of the hall (the ones facing the left side not the ones facing front) as they seem more reliable
if queue too long try the machines on the extreme right side of the hall as they are newer, also there is an customs officer outpost in front of you so if you jump and wave enough they might see you and come to help
If you are leaving JB, you can try the machines on the extreme left side of the hall (the ones facing the left side not the ones facing front) as they seem more reliable
Enrolled previously: Now my Passport expire
Have to enroll again with new passport details sadly
I tried to register and they told me I'm ex-Malaysian so cannot
Anecdotally this is true, so...Malaysia boleh I guess ¯\_(ツ)_/¯
I try everything already and still cannot
Then you have to approach the officers, they'll sort you out
~sabaisabai~
thanks much :o
Habrosus
MDAC
Registration
Fill in your particulars and other information and Submit
Check Registration
Scroll down the page after you Submit, there will be a PDF file to open at the end of the latest entry
Check Visit Pass
I hardly use this, unless I want to double-check for some reason, that the entry and exit for a particular trip is properly captured.
Check eGate Eligibility Status
Don't need to do this unless you've been rejected for some reason or other, or you suspect you're actually not eligible
vsvs24
MDAC
Registration
Check Registration
Check Visit Pass
If have children going, can submit for them using the same email and phone number as mine ?
Does it send an email like the SG arrival card ?
Habrosus
I've never seen the SG arrival card email... Anyway, the MDAC email will show particulars and a PIN to enter when you want to Check Registration.
Not sure about email and phone number. I've only filed for a couple of friends, and used their own. Good question, though... Maybe can?
There's a certain age/height for kids to use the eGates.
vsvs24
Thanks. Not using egates. Just that now manual counters also need to fill MDAC it seems
hwsstx
These few weeks lotsa foreigners visiting MY will have headache filling in MDAC...no WiFi, no link, no app, children, grand parents... Immigration gonna have a havoc time.
This new regulation wasn't decided weeks ago when then all can get prepared but it was cut in yesterday without any grace period. 😂
Looks like nothing much has changed in MY. If can't manage such a simple thing how then to manage Digital IC?
